I am reluctantly selling my 1973 911S sunroof coupe. It is a numbers matching car. I have the Certificate of Authenticity. It was originally a California car, sold into the Pacific Northwest about six years ago. It has no rust.
The car is metallic silver, with factory tinted windows, power windows, wheel arch decos, through the grill foglights, oil cooler lines, limited slip differential, and sportseats. It has Hella H-1 headlights. It has the correct orange bar crest with a beautiful patina. It also has a Vasek Polak license plate frame, though I can't verify its authenticity. It has the correct Blaupunkt Frankfurt radio. I have installed the smaller diameter Carerra RS/914-6 steering wheel, but I still have the original. It has a complete original tool kit, in beautiful condition.
The engine was rebuilt two years ago to original 2.4 liter specs, with new Mahle S pistons and cylinders. The case was done by Ollies, with Timecerts and the oil return valve bypass done. Fuel injection pump by Pacific Fuel Injection. Throttle bodies by Eurometrix. It has a carrerra oil pump, pressure fed chain tensioners and turbo valve covers.
The transmission was rebuilt at the same time, and the limited slip differential was checked and set properly.
The suspension was rebuilt by Fordahls, with only minor changes. It has the aluminum front cross member, aluminum trailing arms, SC adjustable spring plates, 18 mm front (period correct through the body style) and 18mm rear antisway bars, and 22 mm front and 26 mm rear torsion bars. The 6 inch flat face fuchs are in beautiful conditin.
The brakes were rebuilt completely, with refinished alloy front callipers and refinished rear calipers, new rotors, stainless steel brake lines, a new 23 mm master cylinder, and rebuilt pedal box.
The sunroof has been rebuilt. Paint is very nice. I have a stack of receipts. This car is gorgeous, fast, tight, and handles like its riding on rails.
I will send pictures upon request, I have tons. $36,000 OBO. You can contact me at msc73911s@comcast.net.
Update: There is a great deal of interest in this car after only a few hours, and it appears that my initial asking price may have been a bit low. I would not be surprised if the car goes for more than the asking price, so rather than posting another price, I have simply made clear that it will go for the best offer. There are pictures posted in the 911 classified section of Pelican Parts. Thank-you for your interest.
