Thread: Restoration Help
    Restoration Help
    Pulled the 1971 911S out of storage and goining through a full restoration. Rust in the usual places, Rockers, rear door jambs, and fender supports. Bought all the sheet metal and proceeded in drilling out all the spot welds. Surprisingly, the inner rockers and jack posts were in great condition. Oh well, better having too many parts than not enough.
    Question I have is on the replacement outer rockers. Once I fitted the replacement rocker up I noticed that there was a 2" diameter hole on the new rocker sill all the way up front near the door hinges. The original rocker did not have this. I assume the aluminum sill plate will cover this up. Is there a plastic cap that should be in there? Or maybe I have the wrong rocker. It's a aftermarket part so it may be a generic one part fits all, but I figure someone out there might know. Thanks Allan
    1974 914 2.0 Yellow/Black
    The Netherlands
    Restoration help
    Hi,
    Do you mean the square recessed 4 x 2 cm hole? It's closed off a by piece of sheet metal so it's flat with the rocker panel. Shown on my '73 but don't know if the 71 had that original.
    Regards,
    Cees
    Yes, the retangular hole was in my original rocker, but the new rocker has a round hole. Any one know before I weld this part in? Thanks Allan
  1. Restoration of a RHD 2.2S.
    By Alan.uk in forum General Info
    Last Post: 10-12-2018, 04:54 PM
  2. 67S Going for Restoration
    By mwilson3003 in forum General Info
    Last Post: 05-02-2008, 07:28 PM
  3. 911 restoration
    By ydderf911 in forum Technical Info
    Last Post: 12-05-2007, 08:05 AM
  4. restoration
    By lipsgt3 in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 04-28-2007, 10:52 AM
  5. H1 restoration
    By mike walker in forum General Info
    Last Post: 06-15-2006, 09:50 AM
