Results 1 to 10 of 12
Thread: What size and model tires are you RS guys using as Replacements?
    Just as stated what tires are you using?
    I am looking for new tires for the RS Clone I just bought and I'm having difficult time making a selection. There are not many staggered choices available. Maybe I should be looking for a different size.
    I'm looking at:
    205/50/15 for the fronts on 15x7
    225/50/15 for the rear on 15x8
    The best reccomendation a tirerack sales person had was a BF Goodrich tire, which I am not in love with.
    Any help would be appreciated.
    S Registry #835
    Dec 2002
    Birmingham, MI
    Those sizes would look great, but you may want to have a different aspect ratio to keep the overall diameter the same as well as the visual sidewall height - like 205/60/15 and 225/55/15.
    There's a chart on the Tire Rack site I believe that will calculate OAD.
    Don't go too thin on the sidewalls, early cars just don't look right with 50 series tires IMO (225 width may be excepted). Although they obviously will make the car handle better.
    Jared
    '73 911S #0793
    '69 912_ #0602
    Early S #0454
    RGruppe #0391
    I have 205/55 on front in 15x7 and 225/50 15x8 on rear using Bridgestone G3. Love them.
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    The Netherlands
    Tires
    Same tire size as Clyde, only Bridgestone Potenza S-03 on my RS. Great tire in the rain!
    Cees
    Vinny,
    205/50 is too small in the front unless it's for the track. I run 225/50's on 7's in the front and they fit fine. On the rear 225/50's (on 8's) also work...but don't rule out 245/50's on 8's. My rear flares are a little wider than stock but I run these tires and wheels (with spacers too)...and they fit fine. (See my yellow car on the into to the S registry web-site...and maybe this look will work for you.)
    R.
    Jan 2003
    NW Indiana
    Quote Originally Posted by JCR
    This is the size I have on my RS for all the reasons Jared mentions. I have 7s and 8s.
    Brian
    '71T
    R Gruppe #299
    May 2005
    Oroville, CA
    RS tires
    I have seen all sizes come in from 195/50 to 235/60. The closest to the stock size (185/70 & 215/60) is 195/65 & 215/60. Until this month we put on Pirelli P6000, but this month there are no longer listed. The next alt is 205/60 & 215/60 that Yokohama lists. The next sizes that we put on are 205/55 & 225/50 ( at 1" shorter they are usually used for track use, but good for street if you can handle the lower ratio) many companys list these. BFG, Brig, Kuhmo, Mich, and Yoko to name a few. These are all from Tire rack, but you can use the sizes to look at other sources. The one set up that is fun and beefy looking is Dunlop 245/50 & 225/50. we usually put these on ST type conversions but also some RSs. You must check alignment and height specs because of the stagger in diameter. Buy them while you can because they are going away one at a time. I have been watching these monthly lists since CN36s were still available. I tell everyone to buy the tires as soon as you find them because they may be gone next month.
    H
    Man, Harvey's right...
    As I said before... If it wern't for the lack of 'ultra-performance' street tires in the size... I'd still be on 205x60 and 215x60's to this day...
    I can't deney the performance of my S03's in 205x55 and 225x50... but do I miss the ride and look of my 60's.......... plus the speedo is dead nuts on with a later-early car on 215x60's
    Here's a 6 year old profile pic on the old 60's
    Cheers,
    Senior Member 210bhp's Avatar
    Feb 2004
    Scotland
    The correct original sizes front and rear are still available from Avon.
    Mike
    RS#1551(sold)
    67S
    Early S reg. #681
    Oct 2005
    Minneapolis, MN
    195/65/15 or 205/60/15 for the front
    215/60/15 in the rear.
    This combo looks great to me.....I like the fat tire look.
    Aaron Hatz
    Flat Six, inc.
    www.flat6.com
    Follow us on Facebook
    www.facebook.com/flatsixinc
  1. FS: New Porsche 911 seat belt replacements for 1969-1973
    By Perry911 in forum For Sale: 911 Parts
    Last Post: 03-08-2014, 03:35 PM
  2. replacements for switch light rod/tube?
    By 911scfanatic in forum Technical Info
    Last Post: 08-09-2012, 01:31 PM
  3. Purchasing horn replacements
    By karlusmagnus in forum Technical Info
    Last Post: 11-09-2005, 09:10 AM
  4. 911s size wheels and tires???
    By ml911rs in forum Technical Info
    Last Post: 01-14-2004, 12:14 PM
  5. What size tires to use for Autocross?
    By collier in forum Technical Info
    Last Post: 02-10-2001, 07:53 AM
