Thread: 911S 1972 Strähle
    Ready for the Hunaudières manu72S's Avatar
    Nov 2004
    911S 1972 Strähle
    Hi,
    from Manfred Freisinger web site.
    http://www.freisinger-motorsport.de/...e=classic_911s
    pictures
    http://www.freisinger-motorsport.de/...el=album&id=21
    It doesn't seem that its oil tank is not a standart one. Was it a sport factory one or after market one ?
    Manu
    I didn't see a good view of the oil tank in the pics. But the oil filler door looks much the same as on my street production 911S. Heck, looking at those pics, there's nothing "standard" about this car at all! Very impressive car, indeed. But it's not something I'd want to take a 500 mile road trip in.
    I sorta don't think that's an oil tank you see there. If you look closer, the spin on oil filter goes thru the wall as all 72's did which means the tank's on the other side (in fender well area where it's supposed to be).
    Nonetheless, I'd probably offer up my first born for that car.
    Paul Schooley
    S Reg #863
    R Gruppe #330
    Nov 2003
    Sydney
    Manu,
    The plastic 'tank' you see next to the oil filter is probably an overflow catch tank.
    The real oil tank should be in the same position as the road car,ie,between the door jamb and the rear wheel.
    Cheers,
    Dennis.
    S Registry member 536
    Nov 2004
    Hello,
    Yes Dennis, the white tank is a oveflow catch tank. But I talked about this one.
    It has got differents dimensions compared to a standart one.
    Do you think it is only to increase the oil quantity or for an another reason ?
    Cheers
    Manu
    Now that I would see it, I would GUESS to add capacity and to prevent the pick up from sucking air under the harder G loads of a race car. The street '72 911 has less oil capacity than other years.
  1. Replies: 4
    Last Post: 03-03-2014, 11:45 PM
  2. 10. Strähle Porsche Swap - dorf Germany 23.11.2013
    By 67er911S in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 11-26-2013, 09:32 PM
  3. Strähle Swap 24th Nov. 2012
    By uai in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 11-24-2012, 12:26 PM
  4. Strähle Porsche Swapmeet
    By TakeFive in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 11-07-2011, 01:23 PM
  5. Strähle Porsche Swapmeet
    Last Post: 12-04-2010, 01:58 PM
