Results 1 to 10 of 17
Thread: Help installing new carpet!
    I have just received a set of German velour carpets for my 1973 911S from Autobahn Interiors (Tony). The velour carpeting was standard on the 73 S instead of the perlon that other models came with. I am located in Norway and the shipping time was just 6 days!!!
    Does anyone know of a guide on the internet with pictures of installing new carpets in a 911?
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Registered User
    Mar 2004
    carpet drawing
    when i got my carpets the place i got them from sent me a drawing to help in the installation (the numbers represent the order you install the pieces). i scanned it and saved it.
    Dec 2004
    A suggestion
    When your kit arrives, lay all the pieces out in a sunny area on the floor for a couple of days minimum. This helps take out he kinks from shipping and gives you a good idea how the pieces relate to each other in the car. Take your time!
    [SIGPIC][/SIGPIC]
    1967 911S Coupe
    1991 944S2 Coupe
    Past projects:
    1967 912 Coupe
    1969 911T Coupe
    1985.5 944 SR Coupe
    Absloutely! Heat is your friend and 2 cans of adhesive. The 3M is 2nd best and I'm trying to think of the best, common name of auto lubes, etc. Good stuff. Anyone?
    Quote Originally Posted by Zeke
    Permatex? Good stuff too.
    Tom Morgan
    Charlotte, NC
    '18 Carrera T - R #368, S #692
    1973 Giulia Super 1.3
    ..........Wurth
    Mike
    S Registry #825
    73.5 Dalmatian Blue
    A Wurth adhesive (?)
    - In a spray can? Or a tube? ANd is there more than one type - like super-sticky, not so super, etc.
    Quote Originally Posted by 37yrold911
    You can get this at pelican or other places.
    Attachment 20817
    Mike
    S Registry #825
    73.5 Dalmatian Blue
    I just completed this job on my 70S with a set of Autobahn carpets. I used the 3M 'High Strength 90" spray adhes. Dont even bother with the 77 spray.
    My best tip is to go slow. I did one or two pieces per evening so that I didnt get to frustrated. You spent big $$$$ for the carpet, so take your time.
    The worst pieces are the rear wheelhouse pieces. Use you r old pieces as template to show you where to make relief cuts. You will need a big rubber hammer to help stretch the carpet down into the valleys. Those compound curves are a bear!
    1974 911"S" - Silver
    10 sec 67 VW
    Early "S" Registry #439
    Aug 2012
    France
    Reopening the thread. I have recieved my nice and new RS 73 lightweight carpet set....with no installation. I am sute that since 2006, more information are available. I have recorded the installtion drawing on post #2.
    Has anyone got a more comprhensive/step by step installtion guide for this slow and burnout proof exercice ?
    O-G 26 - Early911S 2407
  1. installing new gas tank
    Last Post: 03-16-2013, 10:34 AM
  2. Installing TTG fog lights
    Last Post: 10-25-2009, 04:34 PM
  3. Installing a LSD?
    By andrew15 in forum Technical Info
    Last Post: 10-18-2009, 08:48 AM
  4. swb Charcoal German Square Weave Carpet & trunk carpet kit
    By hoffman912 in forum For Sale: 911 Parts
    Last Post: 06-27-2007, 02:10 PM
  5. Installing new carpets?
    By charlie in forum Technical Info
    Last Post: 09-18-2003, 01:05 PM
