Thread: Battery Move
    Battery Move
    I have a 1970 911 with two batteries. I'm thinking of going to 1 battery in the smugglers box. Any opinions/advice?
    Richard
    A simple search is all you need on this board Richard...
    Try this: http://www.early911sregistry.org/for...single+battery
    Hope this helps,
    Cheers,
    if you are driving the car on the street and the occasional ax or de, get yourself a pair of Sonnenschiens and keep them in the original boxes.
    The car handes BETTER with them up front.
    Like most here, I am familiar with the effort by Porsche to fix high-speed handling by increasing the polar moment of inertia. My 1966 911 has a pair of cast-iron weights in the front bumper for that very purpose.
    So when I put a fuel cell in my 1971 911 race car, I went to a single PC680 in the smuggler's box, which is permitted by the rules. And do you know what? My subjective impressions of the car on the race track, at 1.3g in the corners, are that it actually handles better with more fuel in the cell, i.e. more weight forward. I'm actually going to move the battery BACK to the front box as an experiment.
    Pundits here will tout the "handling advantage" but there is none in my experience. By reducing the mass up front, the car will have less mass to be accelerated when the car begins to rotate, which theoretically means you can open the radius and make the front end match the tail end. In actual race practice, I don't notice a difference.
    Thanks guys, Chuck there is a lot of info out there, on this site and others. John my siuation is much like your track car I have a 100ltr. cell in the car so there is lots of weight up front. I like the Wevo setup and wanted to clean things up around the cell.
  1. Replies: 11
    Last Post: 05-16-2013, 05:29 PM
  2. FS: 15mm wheel adapters (move Fuchs 7R offset wheels to outside.)
    By jameshtaylor in forum For Sale: 911 Parts
    Last Post: 02-05-2013, 03:30 AM
  3. Need to move a 911 from San Fran to Ohio
    By angustami in forum Off Topic
    Last Post: 01-01-2013, 03:47 PM
  4. Sealed Battery Recomendations for Battery Box
    Last Post: 11-13-2007, 05:31 PM
  5. Twin battery to single battery conversion
    By bulldog in forum Technical Info
    Last Post: 03-30-2002, 09:44 PM
