Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: RS steering wheel
    RS steering wheel
    Hi
    Would this be the correct steering wheel for a RS/914-6? I have read a lot of old threads, but really got even more confused than before. I am considering buying this wheel and want to be sure this is the correct wheel. The price is 450£. The partsnumber stamp look a bit funny, what do you guys think?
    john
    edit: just read this old tread, does the wheel in the pic have the 6 holes, if so is this a 914-4 without recess?
    The part number does not mean anything, if the hub face on the outer surface is counter sunk and the rear collar has a 1mm raised lip outside the splines its a 914-4, if it does not have these features it will work on a 914-6 or 911 application. 914-4 wheels came both ways but always had the plastic extension for the 914-4 application. If the outer nut face is flat and the collar is not raised outside the splines about 1mm its what you want. If it is off of a 914-4 and has these features remove the plastic extension and you will likely see that there are 6 not 4 holes for the signal cancel ring. The 2 extra holes are for 911 914-6 applications. I watched many people at the German Auto Fest debating what is right. Shame on anyone who is paying big money for a so called "original RS wheel" or "914-6" wheel. Look at the wheel, again counter sunk? Raised collar? 4 or 6 holes on the back? Forget about the part number.
    Jeff
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    John,
    Yes that appears to have the two important details that say it is in fact a 914-6 wheel. Since the two countersunk holes are there, you just find a turn signal cancel tab from a regular 400mm 911 wheel and add it to this one. Usually they also have a date code stamp but I have one that also does not like this one. If the leather cover is well done that is probably not a bad price. Finding someone to recover them correctly is harder than finding a 914-6 wheel!
    Daron
    Thanks daron
    I am not totaly sure because the thread I refered to from Smith says "914-4 wheels came both ways" both with and without recess, and the way to identify if it was a 914-4 wheel is the plastic extension. On this wheel the plastic exstention could have been removed. I understand this to mean that some wheels where made without recess but with 4 holes and countersunk screws so they would fit a 914-4/914-6 and a 911. To me it looks like this wheel have 4 holes+two countersunk holes? Do anybody have the possiblity to check the partsnumber? Or maybe all wheels with 4 holes + two countersunk wheels and no recess is off 911/914-6 and have been modified with two extra holes to fit 914-4?
    The attached photos are of a real original leather wrapped 914-6 wheel. Hope this helps. Daron
    The Netherlands
    Wheel
    John,
    Hard to read from the picture, but is the part no. 914.347.084.10? How about that date stamp, 86 or 98, pretty odd? That part number I have never seen, should probably read 084.00 or 01 and would be an original leather covered wheel. You need to look for a 914.347.806.10 for a genuine 914/6-RS wheel, 914.347.805.10 for a 914/6 with the thicker layer or 911.347.803.10 and 914.347.805.11 for 914/6 Ersatz (replacement?) wheels. Just to add to the confusion.
    £450,- seems a bit steep for that steering wheel...
    Cees
    Serial is 914.347.087.10, any one know this nr?
    Seattle WA
    John,
    From what I can see, that's not a valid part number, perhaps it was mis-stamped.
    Re-wrapping a wheel is very time consuming and costly. Tony gets $300 for a single wrap, and $350 for double wrap, and I know he would rather do some other job than a wheel wrap. Mark at Vintage Seats gets quite a bit more. Tony has changed a little bit of his methods, and his recent wheels look very nice, and a little cleaner around the spokes.
    Regards, Eric
    #rennfrog
    thanks everybody.
    I think I will pass because the wheel has strange number stamps and a number nobody has heard of. (probably is a 914-6 wheel?) I guess I will keep searching for a 914-6 wheel or maybe i will recover my 914-4 wheel(foam) with one or two layers of leather instead.
    john
    John,
    Thanks for discussing my wheel And I wish you'd been more honest in your personal message on the DDK! If you'd had any concerns over authenticity I would have been delighted to take any more photos you required or put you in touch with the supplier I got it from. I bought it in good faith.
    For everyone's interest, the wheel was purchased from Manfred Herring in Germany late last year, along with a load of other pieces for a 2.4S Targa I was going to restore (that's another story).
    Unfortunately, the pound against the dollar (and other currencies) makes things look expensive - I paid €700 for this wheel and another €100 for the butterfly. The leather work is beautiful and the wheel well restored.
    How the hell would anyone know whether it's genuine - save for the fact that I checked the wheel details with two knowledgable people here in the UK before I bought it - and it came from a reliable supplier!!
    Your implication above by stating 'the wheel has strange number stamps and a number nobody has heard of' - despite that at least one knowledgable person on the DDK has confirmed this is the type of wheel fitted to an RS - is that I am not telling the truth - shame you couldn't have said that to me in your PM on the DDK!
    P
    1973 911 Carrera RS #496
    Early 911S Registry #1808
  1. Replies: 3
    Last Post: 08-15-2013, 09:57 AM
  2. FS: Racemark Steering Wheel -very nice wheel
    By Haasman in forum For Sale: 911 Parts
    Last Post: 11-28-2012, 09:29 AM
  3. Vintage Momo Steering Wheel Question, Identify this wheel
    By rennwagen in forum Technical Info
    Last Post: 08-28-2012, 04:25 PM
  4. Replies: 0
    Last Post: 08-23-2007, 12:21 PM
