Thread: Best Tire Size for a '72 S Targa
    I am going to bite the bullet. I am ready to FINALLY order through Paul K. at AutoKennel, the Michelin XWX for my '72 Targa. It has the original flat six Fuchs. I do want the original look of the XWX, but do I need the extra width?
    Question: Do I go with 195/70 15, or 185/70 15?? Who has which tire size, and why did you pick it??
    I am placing the order tomorrow. Thanks
    [SIGPIC][/SIGPIC]
    Ray Crawford
    Early S Registry #271
    R Gruppe #255
    '70 911 S Coupe 2.9 w/MFI Twin Plug "Flairs n Chairs"
    '72 911 S Targa 2.4 w/MFI
    Ray,
    I believe the car came with 185 x 70's … therefore the speedo should read just right…
    Also you wouldn't be gaining much in width with the 195 x 70's because of the same aspect ratio, only a little in height.
    If you must go with a period correct tire, I'd go with the stock 185's
    If they had a 215 x 60 XWX for the rear to go with the 185 front … You'd be gaining a bunch of width at the exact same height. ………….. You'd be pushing it a little putting a 215 x 60 on a 6… but it would work
    If it were me…. I'd run 7's all round with the most aggressive 205 x 60's front and 215 x 60's rear I could find …. But that's just me…
    Cheers and good luck bud,
    72 with xwx's
    Ray here is a shot of my 72S with flat six's and 185/70 XWX's. If you want another angle, let me know.
    Steve
    Senior Member tfmcmahon's Avatar
    Jul 2003
    Tucson,AZ
    different angle
    These are XWX`s on 185/70/15`s on 7`s all around on my 73E.I have been told by smarter people than me not to go any larger.
    Member:S Registry #864
    Thumbs up
    Now THAT looks GREAT ... the 185's on 7's seem perfect
    Cheers,
    Sunshine State
    The factory tire size is 185/70. Ray, if your car is lowered much at all, you'll probably have clearance problems with the 195/70 (25.8" height). I had 185/70's on 7 inch wheels (slightly lowered) and there was some slight rubbing at the front on the black seal between the fender and bumper.
    Great deal on those Michelins from Paul!
  1. 5.5x15 Tire Size
    By prez! in forum Technical Info
    Last Post: 03-28-2014, 03:55 PM
  2. Tire and Rim size dilemma
    By A.T. in forum Technical Info
    Last Post: 04-14-2012, 08:43 PM
  3. tire size rsr 73
    By gwilliams in forum Technical Info
    Last Post: 12-08-2011, 06:01 PM
  4. Best tire size for a 73 with 7s ??
    By Rennman in forum Technical Info
    Last Post: 07-13-2011, 10:25 AM
  5. 67S tire and size
    By mwilson3003 in forum Technical Info
    Last Post: 09-03-2007, 09:42 AM
