Results 1 to 8 of 8
Thread: Air filter question
    Air filter question
    I know 69+ cars have plastic air filter housings, but could someone please tell me if the 68 housings were also plastic? Are they the same as the 69 MFI ones (i.e. could I put a 69 MFI housing on my 68 Webers)?
    Henry
    Henry
    Hello there.
    No, they are quite differnet.
    The 70-on housings were mostly plastice..and need a different bathtub round the stacks..
    Kind reghatrds
    Hello: Yes you can put the 69-71 metal housing on your 68 Weber car. The MFI will have a enrichment tube inside the housing. You will not need it and can remove it or leave it alone. The 72-73 cars have the plastic housings. Hope this helps. Thanks Eric
    Scope Creep Poster Child
    May 2003
    Eugene, Oregon
    Henry-
    Plastic didn't happen until '72. Steel for '70 and '71.
    -Scott
    Early S Registry 1047
    ’15 VW GTI
    '70 911E, Sold
    '56 Cliff May Prefab
    Thanks to all, what else would I need besides the housing to get my set up back from K&N to original, and how difficult is it to find?
    This is what I have now:
    Thanks again for your patience and help
    Henry
    Henry; Let me have a look to see if I have a carb stock filter assemble. What are doing with the Watershield setup? I'll let you know. Thanks Eric
    The Netherlands
    Wink ...set up back
    Henry....get the 4 holes on the rear bumperettes plugged with the correct plastic plugs...
    Nice engine BTW!
    rgds,
    Cees
    Quote Originally Posted by Eric911S
    Thanks Eric, I don't know what I'm doing with the current setup, but I'll probably keep it.
    Cess, that is an old photo, now they're covered with the right plugs (good eye btw)
    Henry
  1. Which oil filter?
    By Merv in forum Australia
    Last Post: 12-31-2013, 05:40 PM
  2. 72 air filter housing trivia question
    By robmog in forum General Info
    Last Post: 05-04-2009, 06:05 PM
  3. WTB fuel pumps and filter and value question
    By ret9191 in forum For Sale: 911 Parts
    Last Post: 01-12-2009, 08:17 AM
  4. Easy Air filter question maybe too easy
    By A_Alfa in forum Technical Info
    Last Post: 04-25-2008, 12:34 AM
  5. ITG filter set
    By 911pcars in forum For Sale: 911 Parts
    Last Post: 08-01-2005, 01:40 PM
