Thread: Sway bar options for street/autocross car
    My car has sway bars on it currently and as i was putting together an order for new bushings it occured to me that maybe there was upgrade potential
    Assuming i have 15mm sways f/r what are my upgrade options? I don't like the idea of dropping $1,200 on the adjustables if it's avoidable. Not very period correct and i will be lucky if i get to 5 autocross events in a year. I am just hoping to have a good time and learn more about my car while improving my driving skills.
    I have read a bit about 18mm sways from early turbo cars but can't find a definitive thread on installation and any fitting issues.
    Thanks!
    Erik
    Early S # 1107
    All my german equipment is either busted or sold...sigh....in the market for a decent non-sunroof tub!!!!!!! Help me get back to autocrossing!!!
    Your stock bars should be fine, might want to consider upgrading torsions and shocks. All depends on how much you want to sacrifice the ride quality.
    Phil
    Apr 2003
    Portland, OR
    I have 19mm Weltmeister adjustable sway bars front and rear with my stock torsion bars. I like the adjustability for AX since I can add some oversteer at the race course but then can dial them back for street use.
    As I recollect, you have the early through body front bar. You should be able to pick up a used 18/19 mm bars for much less than the $1200 you quote. While there are better bars than the Welty's, for your needs, they may be adequate.
    Harry
    Member #789
    2009 MB C300
  1. front sway bar options
    By Scotty B in forum Technical Info
    Last Post: 11-10-2012, 06:01 PM
  2. An autocross video...
    By davewadd in forum General Info
    Last Post: 01-11-2012, 07:00 AM
  3. parade autocross
    By edmayo in forum General Info
    Last Post: 04-01-2010, 05:04 AM
  4. Autocross mayhem!
    By A.T. in forum General Info
    Last Post: 04-25-2007, 07:45 PM
  5. Autocross setup Help
    By ChrisG in forum General Info
    Last Post: 08-17-2004, 12:06 PM
