Thread: Brake Fluid Reservoir Always Has Overflow
    Nov 2002
    Worshington State
    Even with a tight cap on the brake fluid reservoir, after a few hour drive, the overflow area always contains fluid. Is this to be expected?
    Senior Member HughH's Avatar
    Dec 2004
    Melbourne Australia
    Rick
    check that the rubber seal inside the cap is still there. If it is not there the fluid will leak into the overflow area around the cap no matter how tight it is.
    If the seal is there the area should remain dry.
    If you find it has been leaking because it has not sealed properly it would be wise to do a changeover of brake fluid as it is more likely to have picked up moisture out of the air, lowering the boiling point and reducing its effectiveness
    the rbber seals in the cap are easy to replace but I dont know the part number off hand
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
    Nov 2002
    Worshington State
    Hugh,
    Thank you for the long distance response. I will check for the rubber seal, and regardless, change the fluid.
    All the best,
    Rick
  1. WTB brake fluid reservoir for 73 RSR
    By 60surfer in forum For Sale: 911 Parts
    Last Post: 04-17-2012, 01:03 AM
  2. Replies: 2
    Last Post: 10-11-2011, 11:38 AM
  3. FS New 69 and on brake fluid reservoir
    By fishman7 in forum For Sale: 911 Parts
    Last Post: 09-15-2010, 04:49 PM
  4. FS: Brake Fluid Reservoir
    Last Post: 08-03-2008, 05:54 PM
  5. WTB: 65-67' Brake Fluid Reservoir
    By jhora in forum For Sale: 911 Parts
    Last Post: 10-20-2006, 12:13 PM
