Thread: How do I get the correct finish on my 71' gas tank??
    I know that the original color was a darkish grey color, but when I strip the tank to bare metal, how do I get my tank back to factory finish? Where can I buy the correct grey rubberish finish? I think Wurth is what Porsche used, but I have been searching their website and cant seem to find it as I dont know what category this material is under. Help is needed!
    I believe you're looking for the Wurth Stone guard that is sprayed with the Wurth spray gun. Here's the wurth site you need http://www.wurthusa.com/project/en/l...th=06.0510.jpg Good luck Allan
    1974 914 2.0 Yellow/Black
    As Allan said, it’s the SKS stoneguard that was used originally. I have read a lot of treads about it, and shot with the right gun, right pressure and distance you can replicate the original texture. I remember a tread written by "milt" aka "Zeke" on pelican about how he succeeded in this.
    My selves, I could not get this in Norway because the importer (Wurth Norway) had discontinued importing it because it will not tolerate below freezing storage. That was what the importer told, sounds strange because most warehouses is heated? I ended up using a similar Swedish product in a can, and managed to replicate the look. This was just in a small area inside the trunk.
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Hi,
    In case it helps here is something I have posted on another web site.
    The covering is actually a sealer spray and not stone chip or similar, its more of a rubberised covering.
    "Original sprayable sealer is now on the car. After a bit of testing I have got the finish looking very original. It used around 18 tubes to do all the inner wings, fuel tank, front tank support area and all the engine bay plus a few others areas. Inner wings and engine bay will be painted body colour as per original.
    The fuel tank was also stripped and e-coated before getting a coat of spray sealer.
    Alan
    Texture
    Here is the e-coated tank
    After sealer
    Alan
  1. New fuel tank, worrying about the correct finish
    By clesch in forum Technical Info
    Last Post: 03-04-2012, 09:32 AM
  2. Correct finish for Webasto muffler?
    By Flunder in forum Technical Info
    Last Post: 12-01-2008, 08:48 AM
  3. Correct Finish /Fan Housing 67S
    By Varooom in forum General Info
    Last Post: 02-19-2008, 10:10 PM
  4. Correct Magnesium Finish?
    By Chris G in forum Technical Info
    Last Post: 05-18-2005, 02:36 PM
  5. Correct Finish for '73 P O R S C H E script
    Last Post: 01-11-2005, 05:36 AM
