Results 1 to 10 of 13
Thread: Switch from points or not?
    I replaced the cap & rotor on my car this weekend but did not fool with the points. I honestly don't know what the heck i'm looking at there and the 101 book and Haynes seem to assume some level of experience with these things.
    So............the more i read about points the more i think maybe it's a good idea to switch to an electronic deal where points are eliminated. I don't like the idea of making my engine bay look like a '77 Firebird with cheesy parts BUT if it's more reliable and can offer better power via larger plug gap well......
    So what's the skinny on this stuff?
    Thanks!
    Erik
    Erik
    Early S # 1107
    All my german equipment is either busted or sold...sigh....in the market for a decent non-sunroof tub!!!!!!! Help me get back to autocrossing!!!
    Senior Member Gumby's Avatar
    Jul 2006
    Pine Bush NY
    Erik , so the points setup were ok for 36 years ............
    Ron
    1973.5 911T
    1974 BMW R90/6
    1986 Carrera, Plan "B"
    1987 BMW K100RS Motorsport
    2004 BMW X3 6 speed manual transmisson
    If you don't have a basic knowledge of how to check and adjust points, you probably should have the breakerless system installed. I've been on the side of the road more than once messing with points over the years. That said, If your distributor is in good shape, and the dust shield is in place, they're quite reliable.
    Tom F.
    '67 911S Slate Gray
    '92 964
    #736
    Erik:
    Points are quite reliable but they do not accomodate the normal wear in the distributor that causes unsteady ignition timing.
    Point-less conversions such as Pertronix Ignitors are not only reasonably priced, but also quite reliable and make a very steady, solid triggering signal that doesn't change and offers smoother running. Plus, they eliminate any need to occassionaly check dwell & timing,.......
    I really like 'em,...
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
    steve what all would i need to buy and how much would it cost?
    Thanks!
    Erik
    Early S # 1107
    All you need is the Pertronix unit ($86) and a few hours of your time.
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
    Senior Member CamBiscuit's Avatar
    May 2006
    Adelaide, Australia
    Eric
    I installed a set a while ago (Pertronix) and the car has run like clockwork ever since including 5 days of Tarmac Rallying.
    I'm a fan. Good luck.
    Looking for engine # 6208151
    '74 RS 3.0 Replica
    '70 911E Bahia Red (SOLD)
    '71 911 S/T Replica 2.3 Twin plug BEAST (SOLD)
    Australian TYP 901 Register #78
    Early S Registry # 1076
    you'll get a lot more info ab this on pelican (question of 'numbers') but there are happy users on both sides. i've also been stuck freezing my ass off on the side of the road b/c of points, but once you get the hang of it, it's not too hard to reset them.
    as has been mentioned, they *will* be affected by the health of your distributor. if you grab the shaft and feel any up/down and side-to-side play, it may end up being a factor... a rebuilt, healthy dizzy should be ok. also, i found it's a good preventative measure to just "do" the points every one or two months whether you need it or not since you don't ever plan on having them leave you stranded and it happens at the worst times... snowing/raining, going on a date, rush hour traffic and you're paying toll on the highway... those are all perfect points-failing moments.
    that being said, i was lazy and ended up switching to a pertronix system only to have TWO of them fail on me. maybe just unlucky. my suggestion is buy two, one as a spare, just like you would w/ points, and (pre)wire them both in such way that you can easily reinstall by unplugging two wires and one set screw.
    speaking of which, the screw is small, ~3mm? but it isn't metric b/c pertronix is a u.s. item.... to avoid dealing w/ a 3mm (too small) wrench, and a 4mm (too big), you might as well get a standard that will make your job easier. keep in mind, you may be doing this swap at night, in the freezing cold. plan for the worst.
    }{ what's the status on your car? i saw the bang up pics on dorkiphus and it helped convince me i will only be autocrossing this spring.
    what exactly happens to points that causes the car to crap out? does the gap wear to -0- or what?
    Erik
    Early S # 1107
    Senior Member ennisk1's Avatar
    Jul 2006
    Jupiter, FL
    Erik,
    I'm also very interested in this topic, too. I'm trying to decide whether to switch out the points. I've heard mixed feelings about both.
    Keith E.
    Early 911S Registry #941
    1978 911SC Dirty Penny
  1. Should I go pertronix or go with points?
    By Eli in forum Technical Info
    Last Post: 01-07-2014, 05:08 PM
  2. MSD Ignition Frying My Points!
    By leadrsa729 in forum Technical Info
    Last Post: 10-28-2011, 07:39 PM
  3. Points and distributor
    By ennisk1 in forum Technical Info
    Last Post: 11-06-2006, 01:44 PM
  4. Tie Down Points - 73 vs 78?
    By PanAmeriCan in forum Technical Info
    Last Post: 09-22-2004, 05:01 AM
  5. Points Gap, dwell & timing?
    By pwd72s in forum Technical Info
    Last Post: 08-10-2003, 05:17 PM
