Thread: Mystery piece
    Mystery piece
    I need help identifying the piece below. There was one inside each door of my 71 S when I took it apart. I'm putting it back together now and have no idea where it goes or what it does???
    Anyone
    Thanks, John
    John Ashford
    Towson, MD
    Picture: http://forums.pelicanparts.com/showt...26#post2958726
    Early S Registry #630
    71 911S Irish Green
    65 911 #301826, Silver
    57 Speedster #83702 Aquamarine Blue
    Window stop that goes inside the door. Mine were glued onto the bottom inside door, right about where the front window channel sits. Never knew what it does, but I assume it cushions something that could possibly hit the inside of the outter door skin. Hope this helps, Allan
    1974 914 2.0 Yellow/Black
    Dec 2004
    cushion stop for window winder?
    I believe these pieces dampen the window winder at fulll bottom. With the interior panel off, wind the window to full bottom and see where it bottoms out. I believe this is where the piece goes.
    If I'm wrong (won't be first or last by a mile) I am as interested to know as you are!
    [SIGPIC][/SIGPIC]
    1967 911S Coupe
    1991 944S2 Coupe
    Past projects:
    1967 912 Coupe
    1969 911T Coupe
    1985.5 944 SR Coupe
    Unhappy
    Thanks for the responses. I placed it in several points inside the door and I just don't see where it will have any effect when the window is all the way down. Oh well, maybe its just not that important.
    Thanks again,
    71 911S Irish Green
    Well after playing with them for a while I put them in as below. Don't know if its right or not but it seemed to make sense.
    71 911S Irish Green
    Senior Member red911's Avatar
    Sep 2005
    Rhode Island
    Hi Jashford,
    That is where my rubber "mystery piece" goes too.
    Tom
  1. Mystery 911
    By Chuck Miller in forum General Info
    Last Post: 04-08-2014, 06:49 AM
  2. mystery
    By DavidRS in forum Technical Info
    Last Post: 04-29-2012, 06:56 AM
  3. Marvel Mystery Oil
    By Paul Schooley in forum General Info
    Last Post: 07-14-2006, 03:15 PM
  4. Mystery Seats
    Last Post: 06-08-2006, 09:25 AM
  5. Ignition Mystery
    By jmackay911 in forum Technical Info
    Last Post: 09-01-2001, 08:52 PM
