Results 1 to 7 of 7
Thread: Torque wheel nuts
    The Netherlands
    Torque wheel nuts
    How much (max) torque, in ft-lbs or Nm we put on the 5 Fuchs wheel nuts?
    Thx,
    cees
    Goldmember ttweed's Avatar
    La Jolla, CA
    I use 94 ft.-lbs. Get your torque wrench calibrated. Mine was off by 10 ft.-lbs when it was brand new.
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
    I use 90 Lbs
    2004 GT3 Carrara White with a few mods...
    2011 987.2 Spyder White, LWB's, 6 speed... Crazy Fun!!!
    R #208
    S #607
    A #76
    Sep 2006
    La Quinta
    I use 95 lbs.
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
    The Netherlands
    torque
    Thanks all, I am gonna use 90-95 ft lbs. Just found the specifications book that says 13,0 mkp. I guess that's kilo pounds meter (funny that Porsche mixes metric and imperial units for torque). Rather have ft-lbs, and that's what we use to torque up drill collars/ drill pipe, only a bit a higher at 90,000 ft-lbs ....
    Cees
    Quote Originally Posted by RSexS
    That spec is actually mkg. It is a bastard unit. Torque is measured in force x distance. mkg is mass x distance, so not a measure of torque. The correct units in metric are Nm.
    that is a closer answer. it is in kiloponds and is not a bastard unit, it is a unit of Force defined to be easy to convert into kilograms (the unit of mass)
    http://en.wikipedia.org/wiki/Kilopond
    today, we use N-m for torque
    also that unit had nothing to do with pounds, the US & British Imperial unit for mass or force, depending...
    this will be a useful mini-app for many...
    http://joshmadison.net/software/convert/
  1. 911 wheel nuts
    By jerryg in forum Technical Info
    Last Post: 02-15-2014, 01:58 PM
  2. FS: Minilite wheel nuts and washers
    By Alex Webster in forum For Sale: 911 Parts
    Last Post: 02-12-2012, 12:55 PM
  3. FS - Minilite Wheel Nuts and Washers -10
    By Mudi in forum For Sale: 911 Parts
    Last Post: 06-24-2009, 08:18 PM
  4. American Torque Thrust wheel set 15X7
    By WM711 in forum For Sale: 911 Parts
    Last Post: 09-04-2007, 02:30 PM
  5. Torque value, steel wheel nuts on the track
    By caproader in forum Technical Info
    Last Post: 08-07-2006, 10:10 AM
