Thread: Use 2.4 T MFI heads for CIS car?
    Can I adapt 2.4 T MFI heads for my CIS car? The heads appear to be the same, except for the injector installation. It looks to me as if the CIS aluminum injector holder could be installed in the place where the MFI injector goes, after boring it out. This would also mean making the aluminum injector holders, so I would need a set of dimensions, or find someone who has made a set.
    I have a set of MFI heads with less than 20,000 original miles, and I would like to put them to use.
    Any clues or suggestions would be appreciated.
    Thanks.
    Tom
    Tom F.
    Long Beach, CA
    Fwiw...
    That's like puting socks on a rooster ... more trouble than it's worth.
    You're better off just using the right parts for the application. Save yourself a bunch of time, money and Advil and buy a set of used 2.4T CIS heads and refurbish them.
    Or, you could go the other route and turn the car into an MFI car. However, there's far more work (and parts) invoved in the latter proposition.
    I guess what I'm trying to say is, "Don't straddle the fence." If you want CIS, use CIS heads. If you want MFI, use MFI heads.
    -Marco
    TLG Auto: Website
    Dec 2004
    SE Michigan
    I have '74 CIS heads that I was going to make twin plug MFI heads out of...maybe we should get together...
    Bill G.
    EarlyS #718 | RGruppe #437
  1. 2.4E heads to 2.7RS
    By Andy 74 in forum Technical Info
    Last Post: 06-14-2013, 06:27 PM
  2. FS: 1970-73 911S cylinder heads, matched set of genuine S heads
    By VintageExcellen in forum For Sale: 911 Parts
    Last Post: 03-07-2013, 05:15 AM
  3. FS-NOS heads set of 6
    Last Post: 03-28-2010, 10:53 PM
  4. WTB - 2.8 heads
    By sezme in forum For Sale: 911 Parts
    Last Post: 01-28-2009, 10:45 AM
  5. Heads up
    By 70SATMan in forum General Info
    Last Post: 11-01-2007, 09:03 AM
