Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Stripping, dipping and Ecoating
  1. #21
    Carbon dioxide blasting
    I don't know if this is available in the UK/USA but it is used here in Porscheland quite often for difficult tasks. They blast with very cold gas (dry ice). It doesn't heat up and is non abrasive. You can remove layer by layer. Only the undercoating and leaving the paint underneath untouched or both, one after another. It even doesn't touch the electrics or any kind of rubber, like brake lines or suspension parts. No leftovers, not even moisture.
    I added here two pictures of an unrestored Triumph Herald of a friend. The results were excellent.
    Michael Moenstermann
    Osnabrueck - Germany
    Early 911S member #1052
    'While accelerating the tears of emotion have to flow off horizontally to the ears.'
    'Understeer is when you see the tree you are hitting, if you only hear the tree then it was oversteer'.
    'You can't treat a car like a human being - a car needs love'. (all Walter Röhrl)
  2. #22
    Dry Ice blasting is great,,, but its super expensive... Does a great job of removing undercoat and layers of paint.
    Robert
    [SIGPIC][/SIGPIC]Robert D. Groß
  3. #23
    You guys read my mind on the dry ice blasting...what's expensive?
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  4. #24
    Cost is about 1000 Euro over here including resealing. So I guess with the cheaper labor cost in the US it should be less than 1000 USD.
    Michael
  5. #25
    Considering how much money you can save on disassembling the car using this process, it sounds like a bargain!
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  6. #26
    Quote Originally Posted by nick-moss View Post
    I see that the backdated tub has braces in the doors. This prevents the problem that I discovered a year ago, but my "baker" refuses to admit to!
    So.... What if you had your chassis baked without the door bracing? Can i measure the door opening dimensions? Any idea what they are on a swb? What can you do to fix it? Don't ask me why I am concerned.
  7. #27
    Jun 2012
    London, Ontario, Canada
    The precise dimensions are in the workshop manual for a SWB. Volume 1 or 2, I forget which and I'm not getting out of bed to find out right now !
    We have 4 dry ice blasting services in the city. Its not as expensive as it once was. Brilliant on undercoating.
    Early 911S Registry # 2395
  8. #28
    Senior Member boba's Avatar
    Jul 2006
    DFW
    Here is another thread from 2009 on e-Coat.
    http://www.early911sregistry.org/for...ghlight=E-coat
    65 356SC Dolphin Gray
    66 912 Green
    69 911E Tangerine
    72 911T GP White
    72 911T Aubergine
    72 911T Lilac
    72 911S Black (voodoo)
    90 964C4 Black Targa
    94 964C2 Black Coupe
    08 GT3 Speed Yellow
  1. Dipping vs. Blasting
    By mpotvin in forum Technical Info
    Last Post: 12-05-2018, 03:20 PM
  2. Stripping/dismantling the door of a 66 911
    By MTemp in forum Technical Info
    Last Post: 05-12-2011, 09:34 PM
  3. Stripping inner rear fenders
    By preS in forum Technical Info
    Last Post: 03-04-2007, 06:17 PM
  4. Weather stripping question
    By Mike Baum in forum Technical Info
    Last Post: 06-18-2006, 10:15 PM
