Results 1 to 10 of 19
Thread: What 901 LSD did I just buy???
    Senior Member hgarazo's Avatar
    Jan 2004
    Frederick, MD
    I've been thinking about getting a 901 LSD for my 911L project, and this one became available (Merry Christmas to me!) It looks like it's still in the factory wrapper.
    The hub says: #40610040C4 91921
    The plate says: #4061204001 204001
    Can anyone give me any further details?
    Thx,
    Henry Garazo
    '68 Polo Red 911L Barn Find
    '70T 2.7 Coupe
    '58 1600S T2-A Speedster
    '87 Triple Black Carrera Coupe
    "Form Follows Function"
    Early 911S Registry #962
    Potomac Region PCA
    Henry,
    Call Jeff Ericson at Aase ...
    He has ALL the books and cross-references.
    (714) 992-2283
    And for all that need factory LSD work, Jeff has a bench at the shop just for it. He has a stock of new parts so he doesn't have to order almost anything... so... a very quick turnaround.
    Did a complete rebuild on mine in 4 days...
    Hope this helps,
    Cheers,
    Early 901 aluminum box only. Must have Nadella drive flanges to fit over the stub axles that protrude from the slip. With out the proper flanges that are only found on idential LSD units you have an expensive paper weight.
    Carquip can supply splined flanges so you can use regular CV's.
    Jan 2004
    Frederick, MD
    Thanks guys. I'll call and find out. I hope I can use it!
    Henry Garazo
    '70T 2.7 Coupe
    Potomac Region PCA
    Got a pic without the bag?
    Correct, you can get CV style flanges similar to those used in the 906-910 cars through Critical Operations Inc. The last pair I bought were just under $2,000. They are very nice pieces and require the small 67 type axle/cv size.
    Tom at carquip should have some stock 901 flanges I have splined for him. They will be much more reasonable than $2,000.
    Erich
    Erich, so you have supplied FEMALE drive flanges in CV style for the non preload style LSD for Aluminum transmissions.
    Yes they are Female flanges, Al. case, I am not sure about the non preload. I have them in my 356 (www.stamping.com/excellence.pdf ), which is about half as cool as the orange "bigblock" in the most recent excellence.
    Erich
