Results 1 to 10 of 12
Thread: 902/16
    Regis turd ab user
    Dec 2006
    Tacomatose, Wa USA
    902/16
    Any help identifying 5 spd trans 902/16? What year and applications, similar to 901's? Thanks; David
    68-69 912 here a link to alot of info,
    http://www.early911sregistry.org/for...901+gear+sheet
    Jeff H.
    72 911
    914-6 GT
    Neat box; kinda rare!
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Regis turd ab user
    Dec 2006
    Tacomatose, Wa USA
    Thanks Jeff & Kenik, It does seem to be an odd unit hopefully not in a bad way, it's currently in my 71' Targa with a 2.7 and webers,it seems to handle the torque fine, I just don't want to stomp on it from a dead stop thou, heard stories of pulling first gear out . My car used to belong to Norbert Nieslony, in Palo Alto Ca., heard he's a pretty handy guy, he installed the motor and I wouldn't be suprised if he did this swap also. Hmmmm interesting. Good gears for this set up? Thanks; David
    Mar 2004
    Castro Valley, Ca.
    Norbert was quite a wrench. he's fully retired now after several years being semi-retired. IIRC, his shop was in San Carlos. he was originally @ Howard Motors in Belmont during the Hoffman era. Porsche took over North American distribution ca. '61-'62 & Norbert opened his own place. I believe your 902/16 was special order on some '69 912s & has a 6:29 R&P set vs. the conventional 7:31. gear stack is a little different as well owing to the difference in final drive. A GA O U Z.
    more info here;
    http://www.early911sregistry.org/for...t=13372&page=2
    other than that you have 901 quality gear sets (vs. 914 type)
    HTH
    best
    jerry
    I have two of the 902/16's. They seem to be original equipment 5 speed 901 type boxes installed in 1969 912's. Not sure what the ratios are. Still doing the research.
    However, I have never actually shifter either one of them. One of them came in the car I am restoring (brought it home on a trailer) and the other came from a parts car.
    John, member # 322
    3 silver 73 911's and a 69 912 in pieces
    It's A-GA-O-U-Z
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    It is shorter than 901!
    #rennfrog
    Not to mention, it may be running a shorter ring and pinion, which would be common on a 912!
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Regis turd ab user
    Dec 2006
    Tacomatose, Wa USA
    At 70 mph I,m seeing 3,800 RPM in 5th gear, would that be consistant with the 29:23 ratio assuming speedo is accurate ?
