Has anyone had any luck in achieving good am/fm reception without the use of an external antenna or a windshield-embedded antenna? Car in question is a '70S coupe and radio would be either a Blaupunkt Franfurt or Backer Mexico.
Many thanks,
Many thanks,
Funny that you ask. I just hooked up a Frankfurt that i got recently and was amazed at the reception in my garage without the antenna hooked up. Give it a try.
My ignition is retarded.
You will not have such great luck with AM, tho....
This is too funny.
I just today finished returning my Blaupunkt Frankfurt to its original home in the dash of my 911. I had it refurbished last year but had yet to get around to yanking out the cheap Blaupunkt cassette stereo (made in Malaysia) I had plugged in back in the early 90's. It actually sounds pretty good coming through the old center of the dash speaker. I can remove the stereo speakers I had mounted in the back as I did not cut or damage anything in a permanent way when I originally installed them. I may explore hooking them up and seeing if the output of this old lady can drive them. I really like the retro look, the modern cassette never quite looked right surrounded by the waffle patterned material
Didn't sound too good w/o the antenna plugged in though... But then all the real music comes from the tailpipe anyway
Stefan Josef Koch
RGruppe #194/SRegistry #1063
2015 Porsche Cayman S
Quick answer is no, not consistently anyway. If deleting the attenae is you objective, I recall a kit that you can get that tapes a thin wire around your windshield. I'm sure it's not carried by the auto chain stores anymore given the lack of attenaes for the past couple of decades, but it's something that may show up in a JC Whittney catelog.
1974 914 2.0 Yellow/Black
John,
You may want to try a late 80's windscreen with the antenna embedded into it.Should be some at your local panel shop.
Apparantly these were not too sucessful here in the day as Sydney is a relatively hilly city and reception was patchy.
Just my 0.02 c....
Cheers,
Dennis.
S Registry member 536
Hello; Here is what you can try. Hook up the antenna and lay it in the front trunk and close the hood. I think you will find it will work just fine. After you decide that it works well enough lay it behind the gauge cover. I have done this on 4 cars and it works fine. Hope this helps. Thanks Eric
Thank you all for your input. I am going to try the antenna under the front decklid approach, since it will be cheap and discreet. Desired result is to get local traffic and weather inputs, not concert hall music. No question that all the great mechanical sounds will be the priority.
All best to you.
