Thread: Details for 2.4E needed urgently.
    Senior Member 72911E's Avatar
    Jul 2006
    London / Fort Lauderdale
    HI,
    I have just shipped my '72 2.4E from Tokyo to Hong Kong. I am in the process of getting it registered. All the details I need are in the Porsche red book that is in storage! Need to know the following
    1) Arrangement of valves
    2) Engine Capacity for 2.4 (exact)
    3) Rated Maximum engine power output - - - --KW at --------- rev. per minute (rpm)
    4) Idle Engine speed (rpm)
    5) Tyre specification (front and rear)
    6) Gear box type (model no)
    Need to lodge this asap, so help much appreciated.
    Derek
    Displacement = 2341 cc
    Bore/stroke = 84/70.4 mm (3.31/2.7 inches)
    Compression ratio= 8.0:1
    Output = 165 DIN HP (157 SAE net HP) at 6200 rpm = 121kw
    Max torque = 21 mkg (147 ft. lbs)/4500 rpm
    Gearbox model number = 915
    Wheels/tires = 6j x 15 / Tires 185/70 VR 15 front and rear
    Weight empty=1075 kilos
    Valve arrangement = 46mm intake/40mm exhaust
    Can't find engine speed at idle but I am pretty sure it is around 1,100 rpm's.
    Jul 2006
    Gruen 911 ...that's great .......thanks for your quick reply!!
    Derek,
    I've been helped out on this board a few times myself. A member forwarded me a TUV report for an emissions test in less than 24 hours (faxed from his client's offices while at a meetimg no less) which I desparately needed in order to get my car passed thru the German TUV inspection the next day. I am just paying it forward.
    Now it's your turn to help the next desparate early 911 owner on this board....
  1. WTB: Urgently needed LHS heater control valve in trunk
    By murph2309 in forum For Sale: 911 Parts
    Last Post: 03-22-2014, 08:00 AM
  2. front 73 /74 RSR oil cooler details needed
    Last Post: 03-19-2014, 06:54 PM
  3. JE & Carrillo: inside contact urgently needed!
    Last Post: 06-16-2013, 03:19 AM
  4. WTB 1968 sunroof parts urgently needed!
    By 911r67 in forum For Sale: 911 Parts
    Last Post: 04-22-2012, 07:34 PM
  5. Needed fairly urgently - Early 911 rear wheel bearing retainer
    Last Post: 02-13-2011, 12:21 PM
