Results 1 to 10 of 12
Thread: Need help with paint code
    I've got an unusual number stamped on the paint tag. The car is a silver 71 Targa and the paint code should be 925. But the tag is stamped 8010-H. This car has never been repainted. This has me stumped, can anyone help me here.
    Thanks!
    All the best!
    Roger Grago
    Color code 925 and 924 both refer to a Silver 1970 car, that same code was chandged to 8080 in 1971, are you sure it says 8010? The H probably refers to the paint manufacturer, Herberts in your case
    See here: http://www.elferhelfer.com/farben/farben70-71.htm
    Henry
    Jan 2003
    UK
    Roger - that's the correct paint number:
    8080 is for Coupe models
    8010 is for Targa models
    Up to '71 the plate on the driver's side hinge post shows the paint number & paint manufacturer - not the paint code.
    Andy
    Early 911S Reg #753
    R Gruppe #105
    You learn something new every day
    Henry
    Paint number?
    Thanks for the quick responce guys! Andy I'm confused though. What is the difference between paint number and paint code?
    All the best!
    Roger Grago
    Apr 2003
    Portland, OR
    Check out paint codes here: http://www.elferhelfer.com/farben.htm.
    Harry
    Member #789
    2009 MB C300
    Roger,
    I had same paint code on a 69 S. I could not find the Herberts paint codes anywhere. Came back on COA as a silver.
    Phil
    3910-G Paint Code
    I've got a friend with a 70T 911 with paint code 3910-G. Does anyone know what color this is?
    Bobby
    Bobby,
    3910 is coupe with Olive. One of those love it or hate it colors.
    Phil
    Phil,
    Thanks, This car is a Targa. Same code?
  1. Replies: 9
    Last Post: 01-06-2017, 01:44 AM
  2. Wanted: paint code plate w/ Conda green code
    By 9seriesguy in forum For Sale: 911 Parts
    Last Post: 11-05-2009, 07:33 PM
  3. Name that paint code..
    By budge96 in forum General Info
    Last Post: 08-08-2009, 10:55 AM
  4. how do I remove paint from paint code plate?
    By 911scfanatic in forum Technical Info
    Last Post: 10-26-2005, 06:00 AM
  5. Paint Code help
    By Paul in forum Technical Info
    Last Post: 06-20-2002, 03:42 PM
