Thread: Clutch question
    Rubber centered clutch question
    So, is this a factory friction plate that I found in my 73? Also, my car has an aluminum pressure plate, and it's dated 73, too. So, I am guessing that it's original, which checks out with the service records for the car. I always thought the aluminum pressure plates were aftermarket. Anyone know? Thanks. Tom
    P.S. I changed the title, and bumped this to the top, because I am still curious about this friction plate - it's rubber centered, and PROBABLY original to my 73.5 T. In case it's not clear from the photo, the center of the clutch is rubber, but the rubber is completely encased in a steel jacket, which is what Porsche should have done with the later 911 and 930 clutches.
    Tom F.
    Long Beach, CA
    clutch question
    the alu pressure plates were stock on the 69 and 70S's and maybe thru 73's also. My 71 E's got one.
    Makes a distinct difference in throttle response compared to the steel ones.
    My 73S had an alluminum one as well.
    67 Normale, Old Rusty
    67 R Inspired and on a Diet
    73 T/ST Caged Beast
    RGruppe #383
    S Registry #739
  1. 73 S clutch cover question...
    By mac73s in forum Technical Info
    Last Post: 02-05-2014, 10:55 AM
  2. 71 pull clutch question,I have searched.still stumped
    By chiroracer in forum Technical Info
    Last Post: 04-24-2011, 12:32 AM
  3. clutch disc question
    By 66S in forum Technical Info
    Last Post: 05-10-2010, 09:37 AM
  4. 901 Clutch Question
    By joetiii in forum Technical Info
    Last Post: 08-24-2008, 12:10 PM
  5. 901 (911) Clutch Question
    By CamBiscuit in forum Technical Info
    Last Post: 11-25-2006, 10:37 AM
