Results 1 to 8 of 8
Thread: Installing an "E" cam on a "T" engine
    Hi all,
    I have a 1970 2.2 T engine. Both cams are worn and my mechanic suggests that in search of performance, instead of installing new "T" cams, I should try "E" cams.
    Would somebody please comment what are the risks, problems, or benefits to this alternative?
    Thanks in advance,
    Rafael
    Scope Creep Poster Child
    May 2003
    Eugene, Oregon
    Rafael-
    You will likely need to machine larger valve relief pockets in the T pistons to get the required clearance. Otherwise, this could be a good change.
    Early S Registry 1047
    ’15 VW GTI
    '70 911E, Sold
    '56 Cliff May Prefab
    Will the non-counterbalanced crank of the T be compatible with the E-cams?
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    May 2003
    Eugene, Oregon
    John-
    Those cranks are often used on race motors with S cams, as they are lighter that the counterbalanced variety. I don't see a problem with the combination.
    ’15 VW GTI
    '70 911E, Sold
    You won't be making enough revs with an E cam to cause any risk with the cast non-C/W crank. Good upgrade IMO.
    BTW, the T cranks used in race motors are typically, VERY carefully balanced. Big dollars. They are a long way from a bone stock T crank.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Quote Originally Posted by kenikh
    The non-counterweighted T cranks are forged, not cast, just like all the other 911 crankshafts,...
    Race cranks simply get a lot of prep work including mods for improved oiling at high RPM.
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
    Quote Originally Posted by Steve@Rennsport
    Woops!
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Thank you all for your comments. I will let you know how it goes.
    Best regards,
    Rafael
  1. FS: Special Extended Hub 380mm Thick grip "RS" "RSR" steering wheel
    By Allen Henderson in forum For Sale: 911 Parts
    Last Post: 10-30-2013, 01:47 PM
  2. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 03-17-2012, 07:56 AM
  3. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 03-03-2012, 08:51 AM
  4. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 02-18-2012, 09:24 PM
  5. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 01-24-2012, 01:59 PM
