Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Rear Wiper Questions
  1. #11
    Nov 2003
    Sydney
    The switch below the odometer reset is for an intermittant wiper setup,however its from a '74 onward 911.
    It probably could be adapted to make a rear wiper switch by a highly creative electrical type handyman,I guess.
    I wouldnt be too keen on weighing down the alloy lids with too much accessories - it is too easy to dent one of these as it is.
    My car apparently had an alloy lid with the rear wiper until the late '80s but it seemed to die from corrosion .
    The rear wipers have been an option on 911s from the start and were a common feature of most UK delivered 911s from the late 60s on.
    Cheers,
    Dennis.
    S Registry member 536
  2. #12
    Quote Originally Posted by gulf908
    Ahh... Quite possibly so. This car is rather... ahem... non-original in many aspects... Past owner led me to believe that the rear wiper was original, but so much is modified he may have forgotten himself...
    And no, if I go to putting the aluminum deck on this car it'd be as part of turning it into an ultralight. Not only would the rear wiper not go back on, the A/C would come out.
    Bill Leavitt
    Early 911S Registry #1083
    1969 S... when it left the factory
  3. #13
    Here's a picture of the rear wiper switch (above the turn signal lever) in my '72. It is a hard plastic pull switch. Looks like it could have been a left over part from the 356 days.
  4. #14
    Looks like the little switch I got?
    This is the kind of switch I got with a NOS rear wiper setup I have. It has the motor on the frame, the wiring, arm, blade, linkage and this switch.
    I bought it from a long time Porsche mechanic that closed his shop.
    I probably won't ever use it since I don't want to cut a hole in my rear decklid, but you never know.
    Scooter
    67S
  5. #15
    Rear Wiper
    According to the Work shop manual: Group TRA - Technical Instructions, Accessories:....Rear Window Wiper.
    Installation Kit 901.628.910.00
    "If the installation is to be made into a vehicle model up to 1966 - -
    up to Chassis Nr. 305 100......it will be necessary to also procure the discontinued bellcrank assembly..."
    instructions continue to the dimensions of "locally manufactured" bellcrank spacer and how to drill the lid and brazed-in place the spacer tube.
    So the rear wiper was not offered from the factory until calendar 1966 car #305 100. But could have been dealer installed on earlier cars.
    It was not reflected in the wiring diagram for either L57 (911) or L59 (911S).
    So that would be up thru model year 1967.
    Bob
    Early S Reg #370
  1. FS: Rear Wiper Kit
    By dporsche74 in forum For Sale: 911 Parts
    Last Post: 12-07-2013, 03:19 PM
  2. FS: Rear Wiper Motors, Mounts & Wiper Arm
    By jaudette3 in forum For Sale: 911 Parts
    Last Post: 10-01-2013, 01:10 PM
  3. Turn signal and windshield wiper questions.
    By Chris Pomares in forum Technical Info
    Last Post: 11-08-2012, 12:53 PM
  4. Rear wiper arm WTB
    By 66S in forum For Sale: 911 Parts
    Last Post: 10-27-2010, 02:20 PM
  5. Rear wiper kit for 911
    Last Post: 10-02-2006, 10:54 AM
