Results 1 to 7 of 7
Thread: Best process to rebuild mag case please.
    Registered User Burint's Avatar
    Mar 2007
    Hi
    I bought this 1967 from an older gentleman.
    Original color is Irish green #6606.
    It was modified to the wide body but still shows some detail from 1967.
    The engine is 1971, 2.2s. The car has never been driven in the past 17 years.
    I've been reading about bore align, case saver and other thing.
    For the 35 years old engine, what is the correct process for rebuilding this magnesium case.
    Where should I get this done?
    Thank you in advance for your help
    Burint
    Bangkok
    Thailand
    Burint:
    If you want a good, solid mag-cased engine that will be durable, this is what I'd recommend:
    Install Case Savers
    Deck the cylinder mounting surfaces
    Line hone or line bore as required
    Oil bypass modification (use SC or Carrera pump)
    Shuffle pin (especially in non-7R cases that will see 7K+)
    I would send this to Ollies in LA.
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
    Great project! And all the way in Thailand, no less!! Greetings...
    Peter Kane
    '72 911S Targa
    Ditto for Ollies. Save on freight by breaking the engine down yourself and shipping the engine halves without studs. Even better, if you or someone you know is coming through LA (as most flights from Thailand to the US invariably do), pack the case up as luggage; they are light enough.
    As with anything Steve says...do whatever Steve says.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Oct 2005
    Minneapolis, MN
    Yep.....me too......Ollies in Santa Ana will get it right......
    Aaron Hatz
    Flat Six, inc.
    www.flat6.com
    Follow us on Facebook
    www.facebook.com/flatsixinc
    Hello: Don't aline bore that case oversize. Have the case halves machined then bored back to standard. Oversize main bearings are getting harder to find and expensive. Hope this helps. Thanks Eric
    Mar 2007
    Hi
    Thank you for all the input. Another friend suggests before doing anything, try bolt the case together without a crank or bearings, measure the bore, checking that it is within spec and not oval. If it is within spec, leave it as-is.
    Is there a chance I can get away with this.
    Burint
  1. Wtb: blank aluminum case for 1968 rebuild
    By mpotvin in forum For Sale: 911 Parts
    Last Post: 04-21-2012, 11:32 AM
  2. FS 1972 911T, 7R case with E spec. recent rebuild
    By demo in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 02-15-2011, 02:20 PM
  3. New PCA COA process
    By pu911rsr in forum General Info
    Last Post: 10-20-2006, 04:53 AM
  4. Signal Color Process
    By rsr1975 in forum General Info
    Last Post: 01-31-2006, 07:19 AM
  5. Remains of the RS homologation process
    By fryardds in forum General Info
    Last Post: 04-19-2004, 04:36 AM
