Thread: '71 Targa 911S tires
    Hello,
    I need some help from you. I have a '71 Targa 911S witch is actually with Pirelli P6000 205 R 15. The car is lowered and it's for a street use only (no track). I need to change my tires. My mecanic told me to buy BF Goodrich G Force Sport or Michelin Energy MXV4 Plus. Can you told me what you think about this tires ? Is there a better choice ? Thank you for your help.
    Jan 2006
    Naperville, IL
    I like my Yokohama 100ES's, I have mixed opinions about the Michelins that your mechanic recomended-I think those come on Toyota Camary's. I believe that Chuck Miller runs BFG street tires on his '73S. I would suggest that you stick with a performance oriented tire that is rated to at least an HR? Do you want a classic tread pattern?
    -Andrew
    '72 911E
    '82 931, '92 968, '93 968
    S Reg #1074
    Thank you for the information. Those two tires are V rated. I don't care about classic tread pattern. My car is for every day driving and I would prefer performance to classic look. It seems to be difficult to find a performance tire in the size...
    Senior Member NickP's Avatar
    Mar 2006
    Solana Beach, CA
    tire choices
    Tire choices for our cars with 15 inch rims are limited, especially in a VR rated tire. Go to Tirerack.com and check out their selection to get an idea of what is available. I recently put BF Goodrich g-Force Sport 205/60 15's on my 73S. I first tried the Bridgestone 960 series tire which I didn't care for as it wasn't as direct feeling as the Goodrich tire. I am very happy with my choice, and the price was very reasonable.
    Nick Psyllos
    S Reg & R Gruppe
    1973 Euro 911S
    1972 911T to ST
    To clarify, I run Bridgestone S-03's on the street... and they spoil you, but alas, my sizes are no longer available...
    BTW- The S-03 rears (w/2 degrees negative) last me an average of about 8000 miles before they go off...
    I suggest getting the best performance tire that fits and looks right ...
    Cheers,
    Thank you again for your help. I've been on tirerack.com. The BF Goodrich g-Force Sport 205/60 15's seems to be the best choice. The Yokohama's AVS ES100 seems to be intresting too... I will probably go for the BFG.
    Thank you again
  1. 1969 911S Targa Tires
    By George Klouda in forum Technical Info
    Last Post: 03-31-2024, 07:52 PM
  2. Tires for 1973 911S?
    By 78mochasc in forum Technical Info
    Last Post: 08-17-2016, 02:53 PM
  3. Tires for '72 911T Targa-
    By JFCL911 in forum Technical Info
    Last Post: 01-09-2012, 07:42 AM
  4. What are the best tires for a 911S '73
    By coma in forum Technical Info
    Last Post: 04-13-2011, 09:41 PM
  5. Question about Tires for '67 S Targa
    By craiglazz in forum Technical Info
    Last Post: 01-18-2008, 11:12 AM
