Page 230 of 278 FirstFirst ... 130180220228229230231232240 ... LastLast
Results 2,291 to 2,300 of 2771
Thread: 911T Cars for Sale
  1. #2291
    Aug 2011
    Eugene, OR
    Quote Originally Posted by DOUGS73E View Post
    Quote Originally Posted by Arne View Post
    So it's been tarted up a bit. The rear wiper, fog lights and passenger side mirror aren't listed on the window sticker.
    Too bad it hasn't had a bit more attention to detail. The right side mirror is in the wrong spot, the Weltmeister decal in the window lists 69, 70 and 71 in a 1969 car. (time travel, or just extreme confidence?) Last is the euro turn signal lenses on unmodified US housings, which is a pet peeve of mine.
    Another added tart:
    No Fuchs listed on the window sticker and they're flat Fuchs, not period correct deep sixes.
    And they are later ring cap flats as well. Note the holes in the caps.
    - Arne
  2. #2292
    FS: @BaT - 1973 2.4L 911T Targa
    Bring-a-Trailer Website Auction
    1973 Porsche 2.4L 911T Targa, Lot #29201
    VIN: 9113110198
    Engine: 6130484
    Trans: 7330506
    Color: Ivory (originally Signal Orange)/Beige-Tan Leatherette
    Mileage: 20,556 (indicated)
    Auction Estimate: -
    Sold for: US$38,576 (+BaT Fees on 3/19/20)
    BaT Description:
    This 1973 Porsche 911T Targa was owned in California for many years before moving in the 1980s to Iowa, where it was acquired by the seller in April 2015. The car is powered by its original 2.4L flat-six, which has been fitted with Weber carburetors and is mated to a Type 915 five-speed manual transaxle. Additional features include 15″ Fuchs wheels, MSD electronic ignition, and Turbo-style valve covers. Work performed during the seller’s ownership included rebuilding the carburetors, adjusting the valves, mounting new tires, installing a new alternator, replacing the battery and spark plugs, refurbishing the targa top, and refinishing the wheels. This 911 Targa is now offered in Mesa, Arizona with a Porsche Certificate of Authenticity, tool kit and jack, owner’s manuals, spare parts, service records dating back to the 1980s, and a clean Iowa title in the seller’s name.
    Originally finished in Signal Orange, the car was repainted in its current shade of ivory in the 1980s and also fitted with later-model 911 sideview mirrors. The seller had a “whale tail” rear spoiler removed and the decklid repainted. A new rear grille was also added along with chrome “sugar scoop” headlights rings. The targa panel was refreshed with new vinyl, insulation, and a headliner, and a polished targa bar cover was installed in lieu of an older body-color item. The fog lights are inoperable, and imperfections in the paint can be seen up close in the gallery below. A factory-style sideview mirror is included in the sale.
    The 15″ Fuchs alloy wheels were refinished during the seller’s ownership and reinstalled with new aluminum lug nuts. 195/60 front and 205/60 rear Yokohama YK580 tires were manufactured in 2015. A spare Fuchs wheel with an older tire is stored in the front trunk. Maintenance carried out during the seller’s ownership included rebuilding or replacing the brake calipers, as well as installing new wheel bearings, brake pads and rotors, and brake lines. The brake master cylinder will be replaced prior to the end of the auction according to the seller.
    The interior was reportedly reupholstered in tan in the 1980s. Interior work performed during the seller’s ownership included recovering the door panels, steering wheel, and rear parcel shelf, as well as replacing the window crank handles, dashboard knobs, driver door stop, and vinyl dash trim. The door pouches were also refurbished, electrical sorting was performed, the clock was repaired, new Coco mats were installed, and the shift linkage was replaced by Stuttgart Southwest German of Tempe, Arizona. Cracks are noted on the dash cover.
    Instrumentation includes an 8k-rpm tachometer and 150-mph speedometer. The five-digit odometer shows 20k miles and has rolled over. About 8k miles have been added by the seller during five years of ownership, including a road trip from Iowa to Arizona. The oil level gauge will need to be calibrated, and a removed air conditioning system that was fitted under previous ownership is included in the sale. The passenger door lock is inoperable.
    The 2.4-liter flat-six received a top-end rebuild and clutch replacement at Bruch Motorwerke of Iowa City, Iowa, in 1987 at 64,000 miles, and 40mm Weber carburetors were fitted in 1990. The chain tensioners were replaced and Turbo-style valve covers were added in 1996. An MSD electronic ignition was installed during the seller’s ownership, as was a new battery, alternator with internal voltage regulator, oil pressure sending unit, distributor cap and rotor, fan belt, spark plugs and wires, fuel pump and lines, and a PMO fuel pressure control unit. Oil changes were reportedly also performed every 2k miles, and service in February 2020 included a leak-down test and a carburetor re-jetting by Beck European of Scottsdale, Arizona.
    Power is sent to the rear wheels via a Type 915 five-speed manual transaxle. The car is currently fitted with an aftermarket sport pipe and a factory muffler is included in the sale. Rust is noted in front of each battery box. The Porsche Certificate of Authenticity lists the factory colors and equipment. Engine stamp *6130484* can be seen in the gallery and matches the number shown on the CoA. Owner’s manuals are included in the sale, along with a binder of service records dating back to 1981. A list of work performed during the seller’s ownership can be seen in the gallery, and cold-start and driving videos are view-able.
    Doug Dill
    1973 911E Coupe
    PCA #1987109761
    Early 911S Registry #548
  3. #2293
    FS: @Vintage Motor Cars - 1969 911T Soft-Window Targa
    Vintage Motor Cars, Solon, Ohio
    1969 Porsche ROW 2.0L 911T Soft-Window Targa
    VIN: 119110071
    Engine: -
    Trans: -
    Color: Tangerine/Black Leatherette
    Mileage: 39,200 km (indicated)
    Price: US$87,500
    Dealer Description:
    In 2014, this gorgeous antique underwent a full frame-off restoration including the engine and drivetrain, top end, 2 Weber carbs, brakes and lines, and the front and rear suspension. The beautiful Tangerine base coat is flawless, as is the clear coat. This Targa also boasts a luxurious black leatherette interior that seats four. The Fuch wheels have been restored but are original to the car. We have file photos showing the complete car restoration.
    This soft window model was only offered for three years from 1967 to 1969. In 1969 there were approximately 250 produced. Offered only that year, the long wheel base makes it rarer still.
    This is hands down the finest example of a Porsche 911 that we have seen. A true icon!
    Doug Dill
    1973 911E Coupe
    PCA #1987109761
  4. #2294
    FS: @Car Cave SRQ - 1971 ROW 911T Targa
    March 2019 - Sold at Bonhams The Amelia Island Auction for US$47,040 (including premium).
    Car Cave SRQ, Osprey, Florida
    1971 Porsche ROW 2.2L 911T Targa
    VIN: 9111110088
    Engine: 6110094
    Trans: 7110292
    Mileage: 42,484 km (indicated)
    Price: US$79,900 obo
    Dealer Description:
    The Certificate of Authenticity states that the car was delivered with the engine it retains and quotes supply in this color, as well as confirming that the black leatherette and corduroy seats are original. Other options included Comfort Equipment, Light Metal Wheels and Michelin tires. Completed in July 1970, the 'T' Targa is supported with important and interesting documents which trace original ownership in Germany as per its Fahrzeugbrief where it was delivered new to a Dietbald Krautle of Welfshalde on September 6, 1970, who kept the car for exactly one year, selling it then to Klaus Rampercer on September 6, 1971.
    At some point it migrated to North America in the 1980s, a journey which is recorded by a handful of Polaroids showing the car being containerized. This 911 T was acquired by the previous owner in 2012 on the West Coast.
    As viewed today, the Porsche has an unmistakable honesty to it, of particular note is the interior which is a combination that in preference to leather provides warmth and comfort in all seasons, versus the 'over hot' or 'over cold' of hide. Those interior seats show some age, but not excessive wear and the dash in particularly good condition. In addition to the noted papers a period handbook and wallet are also on file. Having benefitted from a high quality repaint in late 2019 and a full carb rebuild, fluid service, and suspension service in January 2020 this well sorted Targa is ready to enjoy.
    Doug Dill
    1973 911E Coupe
    PCA #1987109761
  5. #2295
    Is anyone 'first hand' familiar with this car? PM me. Doing final due diligence.
    https://autokennel.com/1973-porsche-...fi-2-4l-coupe/
    Chris Purpura @civilizedmisfit
    ___________
    Member #479
    Current Cars:
    1972 911T aka The "Civilized Misfit" Build
    See: https://www.excellence-mag.com/issue...vilized-misfit
    Miss February - EarlySRegistry 2023 Calendar
    1968 911S Ossi Blau/Beige Corduroy
    Past Cars:
    2019 911 Carrera GTS (sold, no regrets)
    73S - #1100 (restored and now somewhere in Europe)
    1997 993 Carrera 4S Black on Black (sold)
  6. #2296
    Mar 2015
    Orange Ca
    Quote Originally Posted by yopurp View Post
    whats the price on the 1973 911T?
  7. #2297
    see listing.
    ___________
    Member #479
    Current Cars:
    Past Cars:
  8. #2298
    Mar 2015
    Orange Ca
    see listing.
    Couldn’t find price “sale pending”
  9. #2299
    Aug 2011
    Eugene, OR
    see listing.
    Listing just says, "Sale Pending."
    - Arne
  10. #2300
    Quote Originally Posted by socalozzy View Post
    US$86,990 was the listed price. It would be nice to know the VIN so we can track the car in the future or look for past posts/threads.
    Doug Dill
    1973 911E Coupe
    PCA #1987109761
  1. 911T Cars for Sale
    By Soterik in forum General Info
    Last Post: 11-22-2013, 07:23 AM
  2. fuel systen on 911T cars
    By motogman in forum General Info
    Last Post: 10-11-2013, 04:14 PM
  3. 1968-69 911T/R race cars?
    By jbronsonl in forum General Info
    Last Post: 05-12-2013, 08:32 PM
  4. 1965 911 Cars For Sale
    By 72targa in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 06-18-2009, 11:02 AM
  5. Cars for sale postings
    By SyarMotorsport in forum General Info
    Last Post: 12-26-2007, 09:44 PM
Tags for this Thread
