Thread: having problem installing rear deck cover
    Hi All, I removed many interior pieces to install my carpet kit. Everything
    was straight forward on reassembly, except for the rear deck (and wall)
    cover. I can't get it to line up so I can screw the luggage strap holders
    in place under the rear window. Can anyone tell me the secret??
    Kjell "Shel" Nelin
    72 911T
    69 E-type OTS
    73 Lancia Fulvia
    Registry Member #1099
    Kjell Gruppen Member #1
    http://web.mac.com/alfaguy/Site/1972_911T.html
    Mar 2004
    Twin cities minnesota
    Rear deck cover
    You must make sure that the metal tabs on the back wall are all in their receivers and pushed fully in place. Then make sure that the top part is laying flat. I used a small punch through one of the screw holes for the final alignment.
    Thanks! I'll try it tonight.
    Kjell "Shel" Nelin
    72 911T
    69 E-type OTS
    73 Lancia Fulvia
  1. Problem Installing New Heat Exchangers
    By Irish911 in forum Technical Info
    Last Post: 01-17-2014, 02:39 AM
  2. FS: 72-73 Rear Deck Cover
    Last Post: 12-05-2013, 06:56 AM
  3. Qs re Installing rear sway ball pins
    By Fishcop in forum Technical Info
    Last Post: 07-07-2011, 01:11 AM
  4. FS: 73 Tan Targa rear deck cover + door panels
    Last Post: 09-13-2009, 06:21 AM
  5. Installing 'glass rear bumper
    By Paul Schooley in forum Technical Info
    Last Post: 05-12-2008, 07:44 AM
