Results 1 to 7 of 7
Thread: Center fill tank
    Member #1525 gilbert911's Avatar
    Oct 2006
    Europe
    Center fill tank
    This is (like) my current tank / spare wheel set up.
    But I would like to change to a center fill tank, with 'inside filler' ie the filler does not go through the hood - like is often seen - rather you lift the hood to access the filler cap.
    What are my options here and how much is it likely to cost me to change?
    Senior Member Grady Clay's Avatar
    Sep 2004
    Unincorporated Arapahoe County, Colorado, USA
    Check this thread:
    http://early911sregistry.org/forum/s...ad.php?t=10874
    I have also written on this subject on Pelican.
    Best,
    Grady
    Jan 2003
    UK
    Chris - it's achievable without changing your tank...
    Andy
    Early 911S Reg #753
    R Gruppe #105
    If you have a plastic tank as in the above photo then you will not be able to convert it to centre fill unless you are a plastics wizard. The factory did use plastic centre fill tanks of a different deisgn. If you have a steel tank then the conversion to centre fill is relatively easy, there are a couple of suppliers if the 100 mm caps and necks here in the UK. Then all you need is a good fabricator who is prepared to work on a fuel tank.
    Jan 2003
    UK
    I should have been a bit clearer with my previous post - the plastic tank can be converted without any surgery but it won't exactly be a centre-fill.
    Here's a picture of how Kurt Zimmerman did his clever conversion:
    ... or if you want a centre-fill metal fuel tank conversion - I can supply one for you (with the correct finned cap).
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Senior Member Rico's Avatar
    Mar 2005
    Fort Lauderdale, FL
    Here's what I did with my existing metal tank and FRP hood.
    Steve
    You could make it center fill if you had the fill pipe mandrel bent to the location ofyour choice...
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  1. Center Fill Gas Tank
    By Richardnew in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 02-23-2014, 07:24 PM
  2. WTB - Center fill gas tank
    By sezme in forum For Sale: 911 Parts
    Last Post: 12-02-2008, 07:08 PM
  3. FS: Center-Fill Tank
    By jaudette3 in forum For Sale: 911 Parts
    Last Post: 11-21-2006, 05:37 PM
  4. 100 liter center fill tank
    By mscott842 in forum Technical Info
    Last Post: 06-14-2006, 04:42 PM
  5. center fill tank
    By fg1227 in forum For Sale: 911 Parts
    Last Post: 12-20-2005, 11:32 AM
