Results 1 to 10 of 12
Thread: 3 prong center caps
    3 prong center caps
    Does anybody fix broken prongs on 3 prong center caps?
    Post photos; maybe one of us can help.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Center Caps
    These center caps came with the car many years ago......nicely hand painted.
    Dec 2004
    I think I have a spare cap if you're interested.
    Just let me know.
    I think you'll run into the problen of having the correct spring tension left in the steel if you try and type of repair on the part and grinding or drilling the old piece of may weaken the replacement of a new spring tab.
    [SIGPIC][/SIGPIC]
    1967 911S Coupe
    1991 944S2 Coupe
    Past projects:
    1967 912 Coupe
    1969 911T Coupe
    1985.5 944 SR Coupe
    Spring clips
    tp67911s
    if you are willing to try a replacement I have a number of the clips here.
    I have taken to saving them after the repeated taking off (when I was racing the car) and having to replace a number of hand painted caps because of a broken clip.
    Now that I have a supply of clips on hand I have only broken one since..go figure.
    I have one cap that I've repaired with JB Weld and enough stud grip to locate the clip.
    Lets say $1.50 for each spring clip. How many do you want ?
    Bob
    Early S Reg #370
    I need the two pictured.....
    I'll send a PM
    Just to let you know......a little JB Weld and the prongs (springs) were replaced.
    Does the JB weld really work?
    Yes indeed......I don't know how it will hold up when the wheels get hot from braking, but for now, after several removals the prongs are holding tight.
    Bob - do you have any of those clips left? I need a couple if you are willing to sell. I have the same problem .. Al Reed finished my caps to match my wheels, but one cap is missing two clips. I'll try the JB Weld trick. thanks!
  1. FS: 3-prong center caps
    Last Post: 04-22-2013, 08:02 AM
  2. WTB: a set of 3 prong Center Caps
    By xpensivewino in forum For Sale: 911 Parts
    Last Post: 01-26-2013, 01:54 PM
  3. FS: Three prong center caps
    Last Post: 02-01-2011, 07:09 PM
  4. FS: 2 3-prong center caps
    Last Post: 12-13-2010, 06:38 PM
