Results 1 to 8 of 8
Thread: Fuel system rebuild questions (early Weber)
    Greetings.
    I used the search feature, and did not find what I am looking for.
    I have Semjon's excellent shop manual on the DVD.
    __________
    I am trying to rebuild the entire fuel system, for a 67 911S.
    I looked up Pelican's parts diagrams and listings. I get to the following:
    Hi pressure fuel hose
    Vacuum Hose
    They sell by the meter. - which size and how long should I choose ?
    mm ID/OD
    How many meters ?
    _________
    Is there any simply (ABC) book, that describes everything in detail ?
    Ralph
    Senior Member CamBiscuit's Avatar
    May 2006
    Adelaide, Australia
    Ralph
    Can't help you with the hoses, why not take a sample off the car and take it to your local autoshop? There are a few weber books out there, also check your local autoshop or I think the dreaded MotorMeister has a Weber manual on their website that you could look at or print out.
    Good luck
    Looking for engine # 6208151
    '74 RS 3.0 Replica
    '70 911E Bahia Red (SOLD)
    '71 911 S/T Replica 2.3 Twin plug BEAST (SOLD)
    Australian TYP 901 Register #78
    Early S Registry # 1076
    Mar 2006
    Louisville KY
    If you have a local VW shop that works on old aircooled beetle's they will have the fuel line you need.
    Tony Proasi
    52 split window coupe
    Feb 2003
    Los Angeles
    I pulled everything out and measured each piece. I bought some of the odd size hose from GPR.
    http://www.gprparts.com/OEMParts/porsche.asp
    Pelican also carries most hose sizes.
    The PET CD and Pelican has some diagrams.
    Good luck.
    Bert Jayasekera
    1970 911T - Tangerine Orange
    Early 911S Registry #494
    R Gruppe #167
    Relaxed Rich Lambert's Avatar
    Jun 2007
    Lake Stevens, WA
    I logged in tonight to ask this exact same question.
    Plus...which fuel regulator should I get?
    And...do I need a fuel pressure guage?
    One more...does anyone have a spare drain plug for a Weber 40? I overtightened one and broke it.
    Last one...the PO installed one of the small Facet fuel pumps. Which pump should I get to replace it? I don't care so much about originality, I just want to get some fuel moving.
    Rich
    '66 911
    Relpacement fuel hose
    The rubber fuel line with the gray fabric and blue line tracer is again carried by your local Porsche dealers.
    (This is by memory so bear with me)
    Fuel hose connections:
    short piece from gas tank to tunnel tube
    Tunnel tube to the engine side rail tube (just above the transmission)
    Side rail to fuel pump (on the left side of the engine compartment)
    Fuel pump to gas filter
    filter to splitter.
    Splitters to carb banjo fittings (2)
    Short section on the webbers between the banjos (2).
    I'm guessing 4 to 6 feet of rubber line. Depending - if you still have the hard line attached to the splitter (at the front of the engine, going side to side -attached to the shock tower cross brace).
    Look for the Norma brand hose clamps, too. You'll use about 18 of them. www.eagleday.com has the yellow cad plated ones at $6 a pop. Others have them in silver at much less.
    Bob
    Early S Reg #370
    Thanks Bob for the clamp info!
    Senior Member Grady Clay's Avatar
    Sep 2004
    Unincorporated Arapahoe County, Colorado, USA
    Ralph,
    Pelican is down right now but there is a LOT on this subject. There is available (I think from Pelican Parts) original fuel hose (C 6 SN 710) 999.180.030.50 sold by the meter. I’m a proponent of using the ’69 and later Norma-Schellen (N-S) hose clamps 999.512.055.02. For ’67 there weren’t positive clamps, only metal sleeves that covered the hose ends. Today, I would never use those except for show.
    The fuel pipe assembly that delivers fuel to the carburetors can have the crimp fittings removed and then use new hose and N-S clamps.
    Unless you are intending to show your 911, I recommend a circulating fuel system. Search Pelican on my name and “circulating”. All FI systems use that and it can be easily adapted to a carburetor system. This reduces the propensity for “vapor lock” and possible carb fires.
    As always, when working with the fuel system, safety is critical. Gasoline is probably the most dangerous substance we are normally in contact with. Please take care.
    Best,
    Grady
  1. Weber rebuild issues
    By fast911s in forum Technical Info
    Last Post: 07-30-2010, 01:48 PM
  2. Brake rebuild/bleed system problem
    By Allen Henderson in forum Technical Info
    Last Post: 11-10-2008, 07:13 PM
  3. Weber rebuild questions
    By Davz912/911 in forum Technical Info
    Last Post: 03-19-2007, 12:52 PM
  4. carb rebuild questions...
    By mjmoran in forum Technical Info
    Last Post: 10-09-2003, 05:34 PM
