Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Step-by-step valve adjustment instructions
  1. #11
    Senior Member karlusmagnus's Avatar
    Aug 2005
    NY
    Ed, now you understand why we have these gatherings in pubs, like McSorleys
    '72T Coupe - Sepia Brown
  2. #12
    I've been told to never remove the spark plugs before a 911 valve adjustment. That can cause deposits to fall between the valve and seat making the valve lash too small when they are gone. Is that a problem anymore?
  3. #13
    I've never had that happen to me, but usually I'll remove the spark plug after I get each piston to TDC for the adjustment, then by the time I'm done the engine has gotten easier to turn. If I'm going to do a leakdown test then I definitely don't remove the plug until the piston is at TDC.
  1. Step Right Up! W123 Diesel Drifter.
    By sithot in forum Off Topic
    Last Post: 10-15-2013, 12:36 PM
  2. Will 912's always be red-headed step child?
    By Frank Beck in forum General Info
    Last Post: 06-26-2009, 04:03 PM
  3. S-Caliper Restoration Step by Step
    By Neunelfer in forum Technical Info
    Last Post: 03-26-2008, 05:40 AM
  4. Replies: 3
    Last Post: 07-21-2006, 06:50 AM
  5. Another step forward for 73VGE
    By larry47us in forum General Info
    Last Post: 03-26-2004, 01:58 PM
