Results 1 to 7 of 7
Thread: Setting up a remote starter switch
    Mar 2005
    I have been having trouble getting my 911S to start since I rebuilt it. I thought it would be helpful if, given that I work on it alone most of the time, to set up a remote starter button so I can fiddle with things as I am cranking the engine. Anybody know the best way to hook up a remote starter switch?
    Don
    Senior Member 210bhp's Avatar
    Feb 2004
    Scotland
    Between the battery and the starter solenoid
    Mike
    RS#1551(sold)
    67S
    Early S reg. #681
    I would put two switches on the electrical console in series. That way they both have to be closed before the starter will crank. You do NOT want to inadvertently crank the starter if you bump the switch, which is avoided by running forward to the cockpit.
    Just as a precaution you may also want to fit a kill switch. It'd be nasty if it cranked and caught at the wrong moment!
    Mar 2005
    Thanks!......................................
    I've posted a procedure to add a remote starter switch on an early 911. It should work on most any Porsche given the same wire color code. Here: http://members.rennlist.org/911pcars
    BTW, for a street car, it's not necessary to install a kill switch. The regular ignition switch performs that function. For service procedures, it's convenient to be able to crank the engine w/o the spark. Adding one also increases the life of the NLA factory ign. switch.
    Sherwood
    I used a 25amp push button mounted in the engine bay. One side goes to the 12V constant terminal on the starter and the other goes to the solenoid terminal on the starter. It works like a charm.
    Cheers
  1. FS: vintage porsche remote controlled cars x 4
    By advtracing in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 03-16-2014, 06:00 PM
  2. WTB - Pre "A" Ignition Switch & Starter Button
    By 1967 in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 09-25-2012, 08:34 PM
  3. torque setting please
    Last Post: 07-24-2011, 09:45 PM
  4. Oil Tank Baffles and Remote Cooler ???
    By Mudi in forum Technical Info
    Last Post: 06-06-2007, 06:53 AM
  5. Remote Starter Switch
    By 911pcars in forum Technical Info
    Last Post: 12-27-2005, 04:23 PM
