Results 1 to 10 of 17
Thread: Engine installed backwards
    Mar 2005
    Only kidding. Now that I have your attention though, after installing my engine after a rebuild I don't seem to be getting a spark. I connected the timing light and I am not getting any light so it must not be sparking. I checked the distributor hook up and it is connected to the permatune and to the relay. How can narrow down the cause of the problem? Thanks in advance.
    Don
    Yearr of the car would be helpful. But did you check/install/connect the speed sensors in the bellhousing? Also check to see if you have all the wiring connected. Power to the coil? Tough diagnosis without seeing the car. Good luck.
    1974 914 2.0 Yellow/Black
    Mar 2005
    Its a 1969 but has PMO carbs replacing the MFI.
    Don...
    Check the permatune
    Mar 2005
    How do I check it? Thanks in advance.
    Don
    Is it a silver of blue permatune? Silver permatunes fail with regularity, blue ones almost never do.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Quote Originally Posted by dhopkins
    Don
    If you can temporarily swap with a know good one, you'll know right away.
    Don,
    As Kenik mentioned the silver ones fail regularly...
    I have one right now that has literally no more than 20 hrs of use and it test ok by the permatune test sheet...but it does absolutely nothing on the car....plugged in a very very old permatune blue one...works fine...plugged in a very old Bosch works fine...the silver one is a piece of crap....opened it up to see what was wrong....you can do this on the Bosch and blue ones...well what do you know...the guts are totally epoxied...this is how they hide the evidence..
    Find a Bosch one....
    Make sure there is source voltage to the unit and it's connected correctly to the system.
    If it doesn't work, reinstall the prior system and get a replacement. The Crane versions seem to be pretty reliable.
    Sherwood
    Good to know
    Contact Loren at: http://www.systemsc.com/
    Tom
    Early S Registry #235
    rgruppe #111
  1. Retractable belts installed
    By Aldo in forum General Info
    Last Post: 12-01-2013, 05:08 PM
  2. Replies: 15
    Last Post: 11-07-2012, 06:18 PM
  3. installed SWB engine photos
    By Neil '67 911S in forum General Info
    Last Post: 08-04-2010, 02:42 PM
  4. Replies: 6
    Last Post: 03-24-2006, 07:37 AM
  5. 'New' 2.7 RS Motor Installed in '73S
    Last Post: 04-21-2004, 07:09 AM
