Thread: Centerlube cam towers and valve cobers F/S
    Mar 2006
    Louisville KY
    For sale both cam towers for centerlube cams anf a complete set of valve covers 235.00 shipped in The Cont.US
    Tony Proasi
    52 split window coupe
    Oct 2005
    wash dc/ los angeles ca
    Centerlube cam towers and valve covers
    May be interested in these if still availalable..whats the difference between
    these and rtegular towers? Thanks Bert
    Mar 2006
    Louisville KY
    These don't have the spray bar for camshaft lube the cams on the early cars were lubed down the center.
    Tony Proasi
    Oct 2005
    centerlube towers and valve covers
    Thanks I see, could I tell from the exterior if my '68 engine has these or not?
    I know its a tech question but could help my decision of course,thanks Bert
    Mar 2006
    Louisville KY
    The 68 usually had spray bar lube do you have an oil line running from the case to the center of the cam tower(between the valve covers) or does it run to the chain housing this is center lube setup
    Tony Proasi
    Centerlube housings do not have the threads/ bolts for oil feed on top. The threads/ bolts/ lines are connected w/ the spray bars inside the housing.
    Richard
  1. Solex Centerlube cam end sealing
    By himizoli in forum Technical Info
    Last Post: 10-21-2013, 02:26 AM
  2. FS: NOS Solex centerlube oil line
    Last Post: 07-02-2012, 12:07 PM
  3. WTB 4 bearing cam towers
    By Bill Harris in forum For Sale: 911 Parts
    Last Post: 03-10-2012, 04:37 PM
  4. F/S - 2.4 E 3-bearing cam towers
    By 911s in forum For Sale: 911 Parts
    Last Post: 01-20-2010, 06:23 AM
  5. WTB: Single Centerlube Cam Housing
    By rcnagel in forum For Sale: 911 Parts
    Last Post: 11-02-2007, 08:55 AM
