Trying to determine if the rear lid grill for a 1967S was all chrome as it came from the factory? Thanks.
Silver anodized aluminum with a satin black mesh.
1974 914 2.0 Yellow/Black
Thank you gentlemen for the quick reply. My mesh is correct, but unfortunately the grill has been painted black. Looks to be quite a project to return to correct finish.
I completely dismantled the grill on '66 to clean it up. I believe there were over 100 separate pieces. I can't imagine stripping paint off all those. Polishing them was bad enough, but it sure came out nice.
Rich
1966 911 #303872
ES#1197
RG#478
Was the 71S also painted black on the deck lid? Thanks AllanOriginally Posted by sithot
Tom,Originally Posted by sithot
I had always thought this to be true until I saw at least one old time period photo from a 1968 issue of Panorama with the entire decklid painted body color. I am not sure which is correct.
_B
Sent from a pay phone
888888 eL, Oph'eL'ia
Instagram: werk_crew
www.werkcrew.com
www.werkcrew.tumblr.com
www.handofwinter.tumblr.com
Considering soda blasting. Otherwise full removal looks near impossible.Originally Posted by Rich Lambert
Dave D.
1967 911S SWT
I take it the Jennings car had this feature intact?
Tom F.
'67 911S Slate Gray
'92 964
#736
To add: 67 lid the black starts 5MM down.
Early 911S member #166
Regarding removing black paint from your grille I faced the same problem with a 356 grille that the PO had painted black. I used a couple of cans of spray on Jasco paint stripper and a toothbrush that I trimmed to fit between the grille slats. I had to go over it several times and I used a garden hose with a pressure nozzle to clean off the Jasco and loose paint after working it over with the toothbrush. After the first pass I thought it would never work but by the second pass it was starting to look pretty good. One more pass did the trick. It was still a pain but much easier than trying to brush on paint stripper or trying to dissemble the grille. Good luck!
