Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Alu. S bumper trim install
    I received the front bumper from the painter today and looked forward to install the S bumper alu trim I bought from Rennspeed. The bumper alu trim came with the thick rubber insert allready inserted into the alu trim, and I installed the two thin stipes of rubber into the backside of the trim that goes between the trim and the bumper. There are two bolts allready molded into each end of the rubber trim that goes through the alu trim and should be inserted through the bumper with a nut on the backside of the bumper. There are no other bolt attached to the alu. trim. There was no other bolts in the kit, but there is several other holes in the bumper that must be for the bumper trim.
    My question is how do I attach bolts to the trim to attach it to the bumper?????? I have been twisting my mind for a few hours, and even tried to grind down a bolt and tried to slide it into the "rail/track" on the inside of the trim, but the bolt will probably spin around in the alu "rail/track" when I try to fasten the nut on the backside of the bumper.
    Anyone else that has bought this trim from Rennspeed that found the solution? Please give me some advice on this!
    BTW I could not get hold of Rennspeed, tried to call them.
    Best
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Mar 2006
    Louisville KY
    You have to take the rubber part off of the trim and install the bolts then put the rubber part back in the groove.Don't overtighten the bolts or you will bend the the trim itself
    Tony Proasi
    52 split window coupe
    Jul 2003
    Santa Cruz, CA
    John, There are special flat head T bolts that slide in the channel to match up with the other holes in the front bumper. This is just like how the rear bumper trim attaches.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Thanks Michael, that is what I suspected when I tried to grind down a hex bolt and slide it in. I will just have to find a bolt with a wider head so it dos not spin around.
    911quest; this alu trim do not have any holes for a bolt to go trough! I took the rubber off to check if there where holes. The bolts will have to be slided innto the innside rail as Michael describes.
    Registered User Burint's Avatar
    Mar 2007
    Hello Zithlord,
    Would you mind sharing with me the quality of Rennspeed alu trim?
    I would like to get the side trims and rear bumper trims for my 67 here in Bangkok.
    Any close up pics.... please?
    BTW. I have been buying from Rennspeed for years,
    it's real pleasure working with them.
    Burint
    911 Front "deco Strip" Hardware
    The Parts You Need To Install The Deco Strip Are As Follows
    901.505.155.20 T-screws Qty 8
    900.025.003.02 5mm Flat Washers
    N021.196.1 5mm Nylock Nuts
    I Have My Front And Rear Bumpers Off At This Time All Repainted And Trimmed Out,ready To Install With A Factory Set Of Through The Grille Fog Lights.....any More Questions Let Me Know.i Have Been In The Porsche Parts Business For 23 Years And I Have The Most Current Porsche "pet" 7.0 On My Computer
    Thanks you guys!
    Burint, I will take the pics this evening(Norwegian time) and post them for you. I think the quality is very nice and Rennspeed was very nice to do business with. Answerd all my question and shipped fast.
    Best
    Burint, the pics you asked for.
    I used some round head bolts, and grinded down two sides so I could slide them into the groove on the inside of the alutrim. Attaching the trim to the bumper was straight froward, just take you time and line up the bolts(now attached to the inside rail of the trim) carefully. Start in one end of the bumper and insert the bolts into the proper holes in the bumper. Tightening up the bolts will make the trim form to the exact curve of the bumper.
    It look very good and the fir was perfect. The thick rubber insert could have been a little bit tighter, but it will shrink after awhile and then it will be perfect.
    The Netherlands
    Rubber insert
    Looks nice John, but if you had bought the original Porsche rubber insert then there would be no gap at all. Don't ask me how I know..... 150 Euro's it is not cheap but definitely a better fit.
    Snakkes, Cees
    Mar 2007
    Hello Zithlord and RSexS
    Thank you for posting pics for me. They look good. I will have to make decision between the genuine or repro. I see a very unique spotlight mount grill you have on your car. very nice.
    RSexS, can you tell me where's the source of the 150 euro genuine trim mentioned in your post please?
    Burint
  1. FS: Early 911 Front Bumper Trim + Rocker Trim
    By METAVINYL in forum For Sale: 911 Parts
    Last Post: 12-04-2013, 10:09 AM
  2. Replies: 4
    Last Post: 06-06-2012, 02:15 PM
  3. Bumper guard install
    By Bob Harriman in forum Technical Info
    Last Post: 03-08-2012, 09:00 PM
  4. FS: Parts from a 70T Bumperetts Bumper Twin Tube Bumper Trim
    By 76911S in forum For Sale: 911 Parts
    Last Post: 08-30-2010, 02:52 PM
  5. Bumper Trim
    By John Straub in forum General Info
    Last Post: 03-16-2009, 05:24 PM
