Thread: How do I know if tensioner upgrade....
    was completed if PO does not? Are there any visual clues?...
    My search for another early car(track rat) may have ended!
    Comp numbers....
    145
    151
    147
    148
    150
    147
    Leakdown
    10
    8
    8
    8
    10
    7
    Ill try to get some pics. Its more of a mildly prepped DE car than a weekend driver. We'll see.
    David Sperow Davz912/911's Avatar
    Sep 2006
    South San Francisco
    tensioner
    If you're refering to the pressure fed upgrade, there will be a small steel tube
    teeing off the cam feed lines going into each cam chain housing cover. Any other upgrade check will require removal of the cam chain housing cover.
    Cheers,
    Dave
    911S registry #1103
    R-Gruppe #513
    1967 912 converted to 2.2
    Period Dune Buggy
    Some drive Porsches' to be seen.....
    I prefer it when nobodys looking.
    Quote Originally Posted by Davz912/911
    Cheers,
    Dave
    I recall seeing those small steel tubes. Ok..thats a start.
    thanks.
    The mechanic who is performing your prepurchase inspection should note whether Carrera tensioners have been installed.
    Quote Originally Posted by 304065
    the car was recently gone thru.....I will try to reach the mechanic
    Pm sent to to you.
    thanks.
    Apr 2003
    Portland, OR
    If you have Carrera tensioners, you will see something like this on the chain covers for your engine (sithot, thanks for the photo).
    Harry
    Member #789
    2009 MB C300
  1. Tensioner kit or not ???
    By derm.1785 in forum Technical Info
    Last Post: 02-16-2014, 06:31 AM
  2. Replies: 0
    Last Post: 10-22-2013, 08:51 PM
  3. Carrera chain tensioner upgrade
    By r14 in forum General Info
    Last Post: 01-28-2012, 07:35 PM
  4. Chain tensioner upgrade?
    Last Post: 03-10-2008, 03:39 AM
  5. How to ID chain tensioner upgrade on 2.2?
    By ulrichd in forum Technical Info
    Last Post: 08-14-2007, 06:41 PM
