Thread: Alternator / Generator
    My Alternator is gone. I haven't done this in a while. Is there someone out there that sells them with return of the core? Someone told me the only option now is to send the original off to be rebuilt... is that true??
    Mike
    S Registry #825
    73.5 Dalmatian Blue
    Senior Member Gumby's Avatar
    Jul 2006
    Pine Bush NY
    I would rather send it out to be rebuilt, It's cheaper and easy, no fiddling around with the wireing and voltage regulator or machining(sp?) of the housing to make a new one fit...IMHO
    Ron
    1973.5 911T
    1974 BMW R90/6
    1986 Carrera, Plan "B"
    1987 BMW K100RS Motorsport
    2004 BMW X3 6 speed manual transmisson
    Mar 2006
    Louisville KY
    Mike not sure where you are located but there are a couple place's in Louisville that can rebuild them for you I can get you some names and phone numbers if you are interested
    Tony Proasi
    52 split window coupe
    Quote Originally Posted by 911quest
    Thanks..I'll take you up on that, I'm in Louisville alot. Bill (wm711) and I will take it out this weekend.
    To make sure that its the problem and not a faulty warning lamp what should the voltage be and where do you measure?
    Mike
    S Registry #825
    73.5 Dalmatian Blue
    Jul 2006
    Pine Bush NY
    Mike , did you check the voltage regulator first?
    Ron
    1973.5 911T
    1974 BMW R90/6
  1. FS: original generator wrench
    Last Post: 01-30-2013, 10:42 PM
  2. Generator Wrench for late 356 and early 912
    By Bert in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 02-07-2012, 01:26 PM
  3. WTB Box End Generator Wrench
    By Allen Henderson in forum For Sale: 911 Parts
    Last Post: 08-18-2009, 02:22 PM
  4. Wanted - bosch 12v 25 amp generator for 1967 912
    By beaker in forum For Sale: 911 Parts
    Last Post: 04-30-2009, 10:44 AM
  5. Fog Lights & Generator Light
    By hdavis in forum Technical Info
    Last Post: 12-12-2006, 02:36 PM
