Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: 901 SWB trans gearing
    I am running a smidge over 3200 rpm at 60mph and a smidge over 3600 rpm at 70mph in my '68 911.
    Anyone care to guess what gearing I have? Do I have "airport gears"?
    The gearing seems a bit short, can't really cruise above 75 mph, rpm's get over 4K.
    Even with my '70 T motor, my car moves out pretty well. Very torquey. It may have to do with my gearing?
    What are other's experiences?
    Senior Member CamBiscuit's Avatar
    May 2006
    Adelaide, Australia
    I've just changed my gearing to AFMSX and am running 205/60 R 15 tyres.
    At 70mph its pulling about 3400rpm.
    What are your tyre specs?
    Looking for engine # 6208151
    '74 RS 3.0 Replica
    '70 911E Bahia Red (SOLD)
    '71 911 S/T Replica 2.3 Twin plug BEAST (SOLD)
    Australian TYP 901 Register #78
    Early S Registry # 1076
    I suspect your gearing is stock. If you had airport ratios you would be turning about 5k at 70mph.
    Tom F.
    '67 911S Slate Gray
    '92 964
    #736
    Senior Member gtgroupe3's Avatar
    Sep 2006
    MD
    MPH estimates.
    These are estimates of MPH for the S-Z gears at 3750-4500 RPM based on tire size with a 901 transmission.
    Calculations do not reflect drive losses and issues with speedometer calibration which can greatly effect actual speed.
    It would be better to have more information of speeds in certain gears in a wider range of RPM. Hope this is helpful.
    3750 4000 4250 4500
    S 61.5 65.6 69.8 73.9
    T 64.0 68.3 72.5 76.8
    U 66.6 71.0 75.4 79.9
    V 69.1 73.7 78.3 83.0
    W 72.0 76.8 81.6 86.4
    X 74.7 79.7 84.6 89.6
    Y 77.9 83.1 88.3 93.5
    Z 80.7 86.1 91.5 96.8
    901 Section Series Diameter
    25.20 185 70 15
    3750 4000 4250 4500
    S 60.3 64.3 68.3 72.4
    T 62.7 66.9 71.1 75.2
    U 65.2 69.6 73.9 78.3
    V 67.7 72.2 76.8 81.3
    W 70.5 75.2 80.0 84.7
    X 73.2 78.0 82.9 87.8
    Y 76.3 81.4 86.5 91.6
    Z 79.1 84.3 89.6 94.9
    24.69 205 60 15
    3750 4000 4250 4500
    S 58.3 62.2 66.1 70.0
    T 60.7 64.7 68.7 72.8
    U 63.1 67.3 71.5 75.7
    V 65.5 69.9 74.2 78.6
    W 68.2 72.8 77.3 81.9
    X 70.8 75.5 80.2 84.9
    Y 73.8 78.8 83.7 88.6
    Z 76.5 81.6 86.7 91.8
    23.88 205 55 15
    Please pardon the formatting, it didn't carry over.
    Sumner
    Registry Member #970
    1970 914-6
    Adriatic Blue
    1972 911T (vice)
    Gemini Metallic
    1967 911S (vice)
    Slate Grey
    Quote Originally Posted by Cam Arnott
    I have 195/65's on my car.
    Quote Originally Posted by tfiv
    Oh, wow, so the airport gears were very short then!!
    Maybe I have "Nurburgring" gears?
    Actually I have no reason to believe the gearing in my '68 is anything other than stock. The RPM's just seem a tad high is all, but that usually happens when comparing older cars to newer cars.
    I think the gearing in the newer 911's was/is geared to high speed cruising on the highway. Maybe the gearing in the older 911's was not focused on this?
    Sep 2006
    MD
    195/65/15
    3750 4000 4250 4500
    S 61.0 65.1 69.2 73.2
    T 63.5 67.7 71.9 76.1
    U 66.0 70.4 74.8 79.2
    V 68.5 73.1 77.7 82.2
    W 71.4 76.1 80.9 85.7
    X 74.0 79.0 83.9 88.8
    Y 77.3 82.4 87.6 92.7
    Z 80.0 85.3 90.7 96.0
    24.98 195 65 15
    Sumner
    1970 914-6
    Adriatic Blue
    1972 911T (vice)
    Gemini Metallic
    1967 911S (vice)
    Slate Grey
    You might find this little utility useful.
    Attached Files Attached Files
    Red face I'm still confused; please advise
    I downloaded the utility which was generously posted. I appreciate the work but am having a hard tme understanding the information.
    I have 225/50-16 rear tires on 16x8 inch Fuchs. I am turning 4000 revs at 80 mph.
    I have the following transaxle numbers:
    typ 911/01
    serial 7112077
    case 911.301.101.0R
    differential housing driver side 901.301.311.2R
    Can someone please tell me what gears I likely have?
    Danke!
    Mar 2006
    Louisville KY
    From the info I have........
    A,GA,O,V.ZA
    But if it has been apart gears could have been changed etc.
    Tony Proasi
    52 split window coupe
  1. Gearing Question
    By Sisuman in forum Technical Info
    Last Post: 06-23-2012, 05:07 AM
  2. US vs RoW gearing
    By Jules Dielen in forum Technical Info
    Last Post: 11-07-2011, 08:54 AM
  3. 901 gearing for a 2.5l engine
    Last Post: 07-05-2010, 03:58 PM
  4. 915 Gearing References
    By gtgroupe3 in forum Technical Info
    Last Post: 02-11-2009, 01:13 PM
  5. Help with Gearing..
    By Mudi in forum Technical Info
    Last Post: 04-18-2008, 07:50 AM
