Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Thru the grill light specs.
    Jul 2003
    Santa Cruz, CA
    Cool Thru the grill light specs.
    I've had some requests for info and reference pics of fog lights for the 67-73's so I thought I'd give it a start.
    I'll add more pics later. All of these are Hellas. Some aftermarket and some Porsche supplied. I'll identify which is which with the pics. In this first batch only the 914 TN4 is Porsche supplied.
    First up is the 118 Driving Light (Italian H1), the 118 Amber Fog (French H3), the the 914 US fog light TN4 (Tungsten),
    Here are the approx. sizes.
    118s: Exposed lense diameter 119 mm
    Case Diameter 135 mm
    Depth (lense included) 67mm
    TN4s: Exposed lense diameter 112 mm
    Depth (lense included) 65mm
    Next couple are the Hella 6" which were typically found on Mercedes and other makes. Interestingly Porsche seemed to have experimented with the 6" H1 driving light judging from reference pics I have seen. First is the H1 driving light. You'll notice the case and mount are similar to the 118s and these will work the same as the 118s in a thru the grill app. Second is a H1 amber fog in a case that is similar but has a different mount.
    H1 Driving/chrome case: Exposed lense diameter 132 mm
    Case Diameter 160 mm
    Depth (lense included) 63mm
    H1 Fog/black case: Exposed lense diameter 132 mm
    Here are the pics in the order I wrote.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Jul 2003
    Santa Cruz, CA
    Next set of pics.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Jul 2003
    Santa Cruz, CA
    More to come, stay tuned.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    show off
    probably better place to put your money these days than the stock market.
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Sunshine State
    This will make a much-needed 1-stop reference. Thanks!!
    Seattle WA
    Michael,
    Yes indeed....thanks for the posting! This will be a good reference for future use.
    Eric
    Thank you sooooooooooooooooooo much!
    Mark
    Jul 2006
    Switzerland
    great info and pics !
    Q: was it possible an early 911 would have mounted 914 TN4 lights with black rims ?
    I've seen this on period photos but I'm not 100% shure.
    Some pre1969 911/911R rally cars do have used Hella's w black rims.
    Was it possible a "regular" 911 would have been equipped with it too ?
    Thank you a for an update.
    Registry member No.773
    Senior Member Neunelfer's Avatar
    Dec 2002
    Sandy, Utah
    What I'm Using...
    I'm using the teener lights. I had them chromed and everything came out great.
    Michael, many thanks for the templates. A little Dremel time and a flat file and... perfect!
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    80 VW “Caddy” Pickup
    72 R75/5 Toaster Tank
    PMB Performance
    Love Us On Facebook
    Seattle WA
    Eric,
    Nice re-chrome. Did you dremel the rivets from the inside? What rivets will you use to put these back together?
    Regarding black lights on a 911, I've yet to see them, there's a pic of one in the RS book, but I doubt that they were ever on car from the factory.
    thanks,
    Eric
  1. SWB Through the grill fog light set
    By Rennman in forum For Sale: 911 Parts
    Last Post: 09-22-2008, 09:15 PM
  2. SWB Through the grill fog light set
    Last Post: 03-07-2008, 04:34 PM
  3. TN-4/ TN1-TN2 Through Grill Light Seals FS
    By MoparBoy72 in forum For Sale: 911 Parts
    Last Post: 03-06-2008, 05:39 PM
  4. SWB Through the grill fog light set
    Last Post: 10-09-2007, 11:46 AM
  5. Another Grill Light Question
    By CamBiscuit in forum Technical Info
    Last Post: 02-12-2007, 12:33 AM
