Results 1 to 10 of 17
Thread: WTB: Single Centerlube Cam Housing
    I need a single center-lube cam housing for an early 1965 911 motor.
    Where are you located?
    Richard
    Hello: Right or left side? Thanks, Eric
    center lube housing
    I could be wrong, but I can't see any difference between a right and left. The part number is also the same 911.105.111.03
    It shouldn't have a spray bar inside and oil fittings on the housing.
    Casey
    Also I'm in Los Angeles
    Mar 2006
    Louisville KY
    I have a set for sale if the other guy's don't work out let me know
    Tony Proasi
    52 split window coupe
    Hello: The early cam housings have a 901 part number. The difference is where the plug is installed. You can change the plug location. The early housings have 6 top studs and 6 bottom studs. Hope this helps. Thanks, Eric
    I have a single and a set of center lube cam housings. I will check for differences and report back.
    Richard
    Just need a single one. PM me for paypal
    I checked the one's I have, ranging from 64 - 65 and they differ.
    The 64 is central lube w/o a cast number on the outside but on the inside. The 65 (central lube as well) does have the casting number on the outside.
    I can not tell wether left and right are interchangeable (but I do think so).
    Which one do you need??
    BTW I have also learned that there are at least 2 versions of the Alu lower covers.
    Regards,
    Richard
  1. Solex Centerlube cam end sealing
    By himizoli in forum Technical Info
    Last Post: 10-21-2013, 02:26 AM
  2. Replies: 1
    Last Post: 09-20-2013, 03:47 AM
  3. FS: NOS Solex centerlube oil line
    Last Post: 07-02-2012, 12:07 PM
  4. Replies: 0
    Last Post: 03-27-2012, 06:00 PM
  5. Centerlube cam towers and valve cobers F/S
    Last Post: 08-06-2007, 08:51 AM
