Results 1 to 10 of 12
Thread: Sealed Battery Recomendations for Battery Box
    Nov 2002
    Worshington State
    I am looking for a sealed replacement battery/s for my old lead acid (paint eating) batteries which will fit the battery boxes - its a 73. Future owners can worry about correctness, I am more interested in preserving my pristine paint. I have no issue with keeping the car plugged into a battery maintainer, but would like the cranking amps to start near zero if left out for 24 hours. Any recommendations?
    What I had in it was an Odyssey PC680 drycell from Batterymart.com. 16 Ah, 25 min reserve. The thing is tiny and light: # Length 7 in., # Width 3 1/16 in., # Height 6 5/8 in. and 17 lbs. http://www.batterymart.com/p-odyssey...j-battery.html
    It died after 3 years, but to be honest I had an electrical drain which killed the battery a dozen or so times. Would 2 of them been a better approach? I like the weight, no leakage, dimensions etc.
    None better; I have two:
    http://www.sonnenschein.org/
    Sonnenscheins rock.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Nov 2002
    Worshington State
    Quote Originally Posted by kenikh
    Sonnenscheins rock.
    Sir Kenik of the Rock,
    Which model did you buy? DF45?
    Sir Rick of the Stick (and carrot)
    I'll look tonight.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    If u search it will come
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Apr 2003
    Portland, OR
    Ed Mayo is a strong advocate of the Sonnenscheins. http://www.early911sregistry.org/for...hlight=sonn%2A
    Harry
    Member #789
    2009 MB C300
    Nov 2002
    Worshington State
    Thanks Harry. The correct size appears to be DF75 for $130 per. I will check to see if there are still leakage problems.
    Hey Rick,
    Not sure if you are stuck on having two, but I put a single Optima on it's side in the passenger-side battery cavity, and thoroughly isolated the driver's side lead. That way if I (or anyone else) wants to go back to two, it's pretty straight forward. I like to think the weight way out there balances the car (with my fat a$$) a little better than the smugglers box.
    My solution might make some cringe, but it hasn't bothered me a bit!
    BA
    Brad Anderson
    911 1970 einspritzung Karmann coupe 0012
    Some kind of happiness is measured out in miles
    Nov 2002
    Worshington State
    LOL! Brad, I like the way you think - distressing - but effective. Used original factory bolts for mounting points. Used steel flat bar and bent to fit like a glove - what a process! (painted semi-gloss). The original battery ground was replaced with a much stronger through the body bolt. It ain't pretty, but it will pass tech.
    Rick,
    Is that an Optima? Pretty slick mounting job. I've been considering two batteries for my 71E, but that looks good and effective.
    Al Kosmal
    the X-faktory
    Current projects; 69-911.5
    76S rat bastard---off to Germany
    1970 914-4...off to Wisconsin
    73 911X Cafe Racer...........(off to S.F.....now racing in Germany)
    66 912 ...off to France
    71E 9111200979 ( gone to Paris..then to Corsica)
    77S (off to NY)
    Early S #1240
    RGruppe #669
    www.x-faktory.com
  1. Battery box
    By kissov356 in forum Technical Info
    Last Post: 04-12-2012, 05:31 PM
  2. just 1 battery
    By rac4bux in forum Technical Info
    Last Post: 02-08-2012, 06:34 AM
  3. cheap sealed battery alternative
    By wanna911s in forum Technical Info
    Last Post: 06-21-2010, 12:19 PM
  4. 67 S Battery
    By steven0401 in forum For Sale: 911 Parts
    Last Post: 06-03-2009, 05:30 PM
  5. Twin battery to single battery conversion
    By bulldog in forum Technical Info
    Last Post: 03-30-2002, 09:44 PM
