Holy moley...nice work!
Rich
1966 911 #303872
ES#1197
RG#478
Rebuilt my calipers back in the late 80's. Today I use the old pistons as paperweights on my desk.
Well done...
Stefan Josef Koch
RGruppe #194/SRegistry #1063
2015 Porsche Cayman S
Very nice job !!!
I rebuild some with new original chromed pistons
#rennfrog
Thanks Guys!
Very nice Oliver. Those are the later Dichromate finished calipers. (I'm looking for a set... anyone want to swap an early set for a late set?)
It looks as though some of the finish may have been bead blasted off or is wearing off. Make sure you get some protection on them.
S-Caliper Tip #1: Vaseline. Protect them annually or bi-annually by rubbing a coat of Vaseline into them. No? Read the factory manual with regard to the maintenance of anodized Fuchs wheels. Anodizing leaves the surface porous. Petroleum Jelly fills those voids and further protects the caliper.
S-Caliper Tip #2 (for anyone with the stock plated pistons):
Change your fluid regularly "regardless" (driven, not driven). A brake system is an open system. Your brake fluid can and will come into contact with the earths atmosphere via your reservoir. In doing so, the hydroscopic nature of the fluid will pull water into the system. This tends to gather around the seals and your pistons will end up looking like the ones in picture #3 in post #2.
This is really a given for any and all of our calipers. These are high performance cars and should be maintained properly. Change your fluid annually. We've torn apart 100's of calipers and SERIOUSLY; you would not believe the difference regular fluid changes make on the calipers. Night and Day.
Eric - Sandy, Utah
71 911
914-6/GT
914-6/ORV
87 944 Spec 1
Porsche Truck
62 Beetle
80 VW “Caddy” Pickup
72 R75/5 Toaster Tank
PMB Performance
Love Us On Facebook
[QUOTE=Neunelfer]Thanks Guys!
Thanks,why not !!!
#rennfrog
Another excellent tutorial. I rebuilt my calipers a long time ago and they did not come out as pretty as yours.
Thanks for sharing.
Bert Jayasekera
1970 911T - Tangerine Orange
Early 911S Registry #494
R Gruppe #167
You took them apart
nice jobYou can't do that every early Porsche repair shop
Early 911S Registry #750
1970 911E - The Good Stuff
2001 Toyota Landcruiser
Shhhhhhhhhhh... don't tell Moorespeed
Thanks!
One more thing Gang,
I have a saying "There's no such thing as a cheap or bragain set of S-Calipers" I get a lot of calls asking what the calipers are worth or, if they should buy a set fo $XXX dollars and that's my patent reply.
Let's say you find a set for $300 bucks. You will almost "always" need new pistons. Add it up:
Calipers - $300.00 plus shipping
Pistons - $215.00 plus shipping
Finish Restoration - $399.00 plus shipping
Compensating Lines $140.00 plus shipping
Total - $1,054.00 plus shipping
Now you can knock some money off if your refinish them yourself but add in rebuild kits, custom o-rings. de-anodizing, polishing and reanodizing.
They are some of the coolest calipers on the planet but... not cheap.
E.
Eric - Sandy, Utah
71 911
914-6/GT
914-6/ORV
87 944 Spec 1
Porsche Truck
62 Beetle
PMB Performance
Love Us On Facebook
O.K. It's time I get in on the fun. Who want's to pay for this junk?
Tom
Early S Registry #235
rgruppe #111
Another fine job and tutorial Eric. I knew I had hit the jackpot when I received the 67S set I sent you for refurb a few months prior. I have a pair of latter dichromate, PM me. Mark S.
Early 911S member #166
