Results 1 to 10 of 18
Thread: Color Search and paint Code
    Question Color Search and paint Code
    Hello All,
    I recently purchased a 71 911 E targa. The car is mostly in primer but it is originally some color of green, possibly metallic. The tag on the door jamb reads 8031- H. Unless I 'm remembering it wrong. It might be 8310-H. I can look this evening. Does anyone know where I can look up the color? I've tried the usual suspects?
    TIA,
    Leonard
    Leonard,
    Try this:
    http://www.elferhelfer.com/farben.htm
    It might be #8383 under '70-'71
    Hope this helps,
    Cheers
    Hi Chuck,
    Thank you!
    I have tried that site with no luck. The number is definitely not the 8383 it's a version of the original post and it ends in the - H.
    Maybe I should post a pic of the tag on the door jamb?
    I could get it tonight.
    Thanks for your help!
    Leonard
    Jan 2006
    Naperville, IL
    8310 is Green Metallic and correct for a '71. If you want you can search the formula on this.
    -Andrew
    '72 911E
    '82 931, '92 968, '93 968
    S Reg #1074
    Jan 2006
    Naperville, IL
    Select;
    Porsche for the Manufacturer; Code 8310 in the code box. Then select start search.
    I thought that the -H- stood for "Herberts" another paint supplier.
    -Andrew
    '72 911E
    S Reg #1074
    Interesting, thank you Andrew!
    So I guess it's just green metallic no name? I tried that site earlier but never entered the year.
    I wonder why I don't find it on any of the other color code charts?
    Thanks again Andrew.
    Leonard
    http://www.911c1.de/porsche/Technik/...code_gruen.htm
    83 grün-metallic 1973, targa colors ends in 10
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Thank you everyone for the responses.
    Chuck your initial thought was correct. I spoke with John Patarek yesterday and he stated that #8310-H was a targa specific code. Coupes were the same color only #8383. He didn't know why the codes were different.
    The Glasurit code is 221.
    Metalic Green it is!
    Thanks Moparboy and John.
    Leonard
    Senior Member karlusmagnus's Avatar
    Aug 2005
    NY
    Quote Originally Posted by LeonardZ
    Leonard
    Perhaps in a production environment, when you were planning to paint a coupe vs a targa, you would use a different volume of paint and so it would be useful to have this codified?
    '72T Coupe - Sepia Brown
    Hi,
    Sorry if I saw your thread earlier I would have helped. But just to confirm here is a pic
    Alan
  1. Paint color code and name
    By Paul Tosi in forum General Info
    Last Post: 10-02-2021, 08:30 AM
  2. 911R color/paint code white
    By v-8 in forum Technical Info
    Last Post: 05-16-2014, 01:58 PM
  3. Question about Paint Color/Code
    By Jazzman in forum General Info
    Last Post: 12-17-2010, 08:13 AM
  4. Engine compartment paint and color code
    By ferry58 in forum Technical Info
    Last Post: 10-12-2009, 12:12 PM
  5. paint color code in 1973
    By RandyWebb in forum General Info
    Last Post: 09-14-2005, 03:01 PM
