Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Caliper rebuild. Where to send them to?
  1. #11
    Loud lederhosen saves lives hoffman912's Avatar
    Feb 2003
    classic and speed parts has a remanufactured brake caliper program for 911 and 912 brakes
    http://classicandspeedparts.com/inde...d409a9c4239e30
    Our show-quality caliper restoration process meets or exceeds original equipment performance and appearance while it simplifies the core return process! Each caliper is completely disassembled, media blasted and crack tested prior to being re-plated in the correct, original yellow zinc finish. Each caliper is then carefully reassembled, using new stainless steel pistons, new seals, all-new through-bolts and nuts, new bleed valves and dust caps, new brake pad pins, clips, expander springs and hardware. Kit is complete set of both front calipers. There is a core charge of $100 each caliper. For your convenience, we have packaged the kit with core return instructions, re-useable boxes, heavy-duty zip-lock bags and UPS return labels
    Harry Hoffman
    356 Registry Member #36691
  2. #12
    White Post Restorations. 2 day turn around. Perfect.
    Tom
    Early S Registry #235
    rgruppe #111
  3. #13
    Feb 2007
    Thousand Oaks, CA
    My .02 cents
    Just wanted to throw a vote to Eric @ PMB Performance. He's done my 2nd generation S calipers and my rear M calipers. Quality is top notch . . . better than new and his turnaround has always been more than acceptable.
    They are so nice I almost hesitate to install them and get them dirty.
    Tom Ching
    69E Burgundy
  4. #14
    me too have send them to Eric/ PMB performance
    Apparently there are several places that do a good caliper rebuilding job. I have send them to Eric since he is sharing a lot of his (inside) knowledge w/ us which I appreciate.
    I look forward to the results.
    Richard
  5. #15
    Senior Member Neunelfer's Avatar
    Dec 2002
    Sandy, Utah
    Thanks guys. Sounds like those other guys do great work as well.
    One of the big questions that has come up is; can I convert early 911 L-Calipers to Wide L-Calipers for the vintage S application? I think I'll start another thread on this showing the differences between the two L-Calipers, this way others can find it easier etc. There are quite a few major differences that would probably prevent the L to Wide L conversion.
    By having Ken's L-Calipers and Richards Wide L-Calipers in the shop at the same time it will be a good time to show all the details.
    Richard... everything is off to the platers. Pistons came out just fine.
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    80 VW “Caddy” Pickup
    72 R75/5 Toaster Tank
    PMB Performance
    Love Us On Facebook
  6. #16
    Wow Eric,
    I didn't realize you were the Yoda of brakes. Wish I knew that before the whole new caliper purchase thing. Lesson learned, ha ha. I'll ask and see if there are experts before running amok half cocked next time. I'm just excited about getting this thing running expediciously.
    Scott
  7. #17
    Dec 2002
    Sandy, Utah
    Uhhhhhhhhh... More like the "Goober" of brakes.
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    PMB Performance
    Love Us On Facebook
  8. #18
    Vertex calipers
    Has anyone ever used Vertex in Miami. They send out rebuilts for $259 with a $100 core charge. I've had a lot of luck in the 80's and 90's with them wonder about them today.
    Mark
    52 Coupe
    56 Speedster
    63 Cab?
    1969 911T
  1. FS: Ate Caliper Rebuild Kit 250102
    By 76911S in forum For Sale: 911 Parts
    Last Post: 05-17-2011, 07:13 AM
  2. FS: Caliper Rebuild Kits
    By John912 in forum For Sale: 911 Parts
    Last Post: 08-17-2009, 12:33 PM
  3. 911S and 914/6 #1 caliper rebuild
    By Nate Y. in forum General Info
    Last Post: 06-30-2007, 05:15 PM
  4. Replies: 33
    Last Post: 11-02-2005, 03:13 PM
  5. '67 S brake caliper rebuild
    By Ed B in forum Technical Info
    Last Post: 02-24-2005, 07:38 PM
