Thread: MFI spec.
    MFI spec.
    A friend can buy these but do not know what they are. This is all the info I have:
    MFI Pumpen - 0408 126 014 = 1973 911 E
    Stacks, 911 110 314 1R, 36 mm messured at the bottom = ?
    Trottle bodies, 02/73, approx. 37 mm at the top and 32 mm at the bottom = ?
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    MFI specs
    Plastic stacks are 72-73 2.4E (314)
    Throttle bodies are 38mm top/32mm bottom. If there are any numbers on the front of the housing (vertical area) near the vacuum tube they are '73 2.4E No numbers = '72 2.4E.
    Matt
    Thanks Matt!
    What are the messurements for the stacks and trottle valves, top and bottom, on the S and RS?
    MFI specs
    '72S and '73S and RS plastic stacks are the same part (312). They are about 43.5mm at the top and taper to 38mm at the bottom.
    '73S and RS throttle bodies are the same part and are 38mm at the top and taper to 36mm at the bottom.
    Matt
    Matt; thanks!
  1. 2.4E to 2.7RS spec
    By Andy 74 in forum Technical Info
    Last Post: 03-20-2019, 08:56 AM
  2. Italian Spec vs US Spec 911S?
    By 73ess in forum General Info
    Last Post: 01-14-2014, 03:10 AM
  3. Need spec details of 1968 Euro (ROW) S vs. US-spec 1968 S
    By Peter Linsky in forum General Info
    Last Post: 10-20-2011, 03:23 PM
  4. 28.5 MPG with a 2.7 RS Spec MFI?
    Last Post: 12-25-2008, 07:01 PM
  5. F/S 73 911 2.7RS Spec.
    By Bobby Smith in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 06-30-2006, 10:48 AM
