Results 1 to 10 of 10
Thread: Paint Code 97-6206-1
    OK paint de-coders, what color is denoted by this number on the door post tag of a 67 S: 97-6206-1?
    Thanks for the help,
    Early 911S Registry
    Looking for engine 960 168
    Looking for gear box 103 165
    Time Bandit Jens's Avatar
    Aug 2003
    vahmont
    Wink
    Dark Green Metallic?
    RGruppe #183
    Aug 2003
    vahmont
    Probably Silver Metallic enamel from '62-'63.
    RGruppe #183
    67S #305631S also has 6206 paint code. It is 1962 356B Metallic silver.
    Tom,
    I don't see that particular code in any of my books. If it follows the the 64-65 and the 66-67 pattern, it would be Irish Green, pure speculation on my part.
    Phil
    A prefix number 97- signifies that the original paint was 140 degree C / 284 degree F 'baking paint', oven cured with all heat sensitive parts removed. Suggestion: Don't try that at home
    The 6206 is most likely Silver Metallic and the code is a 356 one. The -1, don't know...yet.
    Aug 2003
    vahmont
    Exclamation Sheesh!
    The clue was '62-'63, the 356 production era.
    Tom, you can reference it there.
    RGruppe #183
    Guys:
    Thanks for the responses; most helpful. The car in question shows evidence of having been silver.
    Jens: Thanks for the '62-'63 tip; wonder if the first owner had owned a B in that color that he especially liked.
    Dr911E: I have been told that the the "dash one" suffix on the paint code denotes a special order color.
    Thanks again,
    Early 911S Registry
    More likely not a B in that color but was it the only silver available in 66/67, a Sonderfarbe (special color).
    Richard
    Dec 2016
    Squalor Heights, CA, USA
    Quote Originally Posted by 66S View Post
    If you still have this car I'd love to compare notes. I have 305628S / 6206. It's now red but started life silver.
  1. 72S paint code 936-9-3
    By dummkopf in forum Technical Info
    Last Post: 10-15-2013, 03:57 PM
  2. Wanted: paint code plate w/ Conda green code
    By 9seriesguy in forum For Sale: 911 Parts
    Last Post: 11-05-2009, 07:33 PM
  3. 73 E Paint Code
    By kenaichoochoo in forum Technical Info
    Last Post: 12-29-2006, 02:09 PM
  4. how do I remove paint from paint code plate?
    By 911scfanatic in forum Technical Info
    Last Post: 10-26-2005, 06:00 AM
  5. Paint Code help!
    By MY911S in forum Technical Info
    Last Post: 11-13-2004, 05:55 PM
