Results 1 to 2 of 2
Thread: Sill detail on 65 911
    Hello everyone,
    We're fixing a few rust spots on my 65 and I lifted the rubber sill covering because it was raised up in a few places. Sure enough, rust.
    The surprise was that the sill has a series of rectangular indentations that had been filled with bondo, or something very like it. The rear three filled indentations had rusted. I chipped it out of one unrusted indentation and under the bondo was perfect shiny paint.
    Has anyone seen this? It can't be factory, can it? The best guess we came up with was that an early owner didn't like the fact that the sills weren't smooth and flat so he had someone make the sill flat. Of course water ran under the rubber cover and soaked into the raw bondo causing the rust.
    Our plan is to remove the bondo, repair the rust, and put back the rubber covering. So far it's still two rust spots below the corners of the rear window and rust in both rockers with no other rust.
    Sep 2006
    La Quinta
    From what I remember, what you found was correct for a '65, the factory put it in there to make it flat.
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
  1. Looking for detail pictures of RS #285 or 288
    By GeorgeK in forum General Info
    Last Post: 12-17-2015, 06:21 PM
  2. Porsche Detail
    By PMR71E in forum Australia
    Last Post: 12-03-2013, 02:33 PM
  3. 1965 Sill/Jacking Point Detail Photo Needed
    By Schläfer in forum Technical Info
    Last Post: 11-29-2010, 11:06 AM
  4. 917 Detail Pictures
    By thorsten73 in forum General Info
    Last Post: 02-09-2005, 03:16 PM
  5. rs detail differences?
    By james in forum General Info
    Last Post: 11-20-2004, 09:24 AM
